Good Evening everyone
After upgraded from OH2.4 to 3.0 I tried to migrated it but it crashed so I need to start from scratch my whole system based on the idea of my old OH2. It is hard but it is working.
The system data are:
Platform = Raspberry Pi Model B Plus Rev 1.2
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Kernel : Linux RspiOpenHAB 5.10.17+ #1403 Mon Feb 22 11:26:13 GMT 2021 armv6l GNU/Linux
openhabian version: 3.0.1 (Build)
openjdk version: “11.0.10” 2021-01-19 LTS
OpenJDK Runtime: Environment Zulu11.45+27-CA (build 11.0.10+9-LTS)
OpenJDK Client: VM Zulu11.45+27-CA (build 11.0.10+9-LTS, mixed mode)
The thing is I adopt the old rules that worked on OH2 but I’ve a problem with this one that “double-check” the movile phones’ presence executing
a script based on the command “ip neigh show” after a lapse time that the rule was fired. The script return a simple ON/OFF string and there is a if / else to decide what to do.
But it doesn’t work, all the time ignores the “ON” value.
This is the rule, and Script and the logs:
//************* Desactivacion GSw Presencia ***********
// GSw Presencia changed from ON to OFF >> Nobody in the house => change Switch Post_Presencia to OFF
rule "Ausencia"
Item gPresencia changed from ON to OFF
var PresenciaExec = "OFF"
// Made a timer for waiting 2 min and then check there is no movile in the network
// executing the BASH Script Phonedet.sh that use the command "ip neigh show"
logInfo("CheckAusencia.rule", ">-- It seems that there is no active Mobile. It will be rechecked in a while.")
createTimer(now.plusMinutes(0).plusSeconds(20), [|
logInfo("CheckAusencia.rule", ">-- Value PrensenciaExec before evaluating Phonedet.sh: " + PresenciaExec)
PresenciaExec = executeCommandLine(Duration.ofSeconds(10), "/etc/openhab/scripts/Phonedet.sh")
logInfo("CheckAusencia.rule", ">-- Value PrensenciaExec after evaluating Phonedet.sh: " + PresenciaExec)
if (PresenciaExec == "ON" ) {
Post_Presencia.postUpdate(ON)
logInfo("CheckAusencia.rule", ">-- Maybe was a false desconexion")
logInfo("CheckAusencia.rule", ">-- Switch Post_Presencia ON")
else {
Post_Presencia.postUpdate(OFF)
logInfo("CheckAusencia.rule", ">-- Confimed nobody at the House")
logInfo("CheckAusencia.rule", ">-- Switch Post_Presencia OFF")
#!/bin/bash
status=OFF
statusprev=OFF
MOVILES='192.168.1.31 192.168.1.36 192.168.1.34 192.168.1.35 192.168.1.37 192.168.1.38'
#MOVILES='192.168.1.31'
for i in $MOVILES
do
statusprev=`ip neigh show | awk '{print $1,$6}' | grep $i | sed -e "s/$i //" -e "s/REACHABLE\|STALE\|DELAY/ON/g"`
if [ "$statusprev" = "ON" ]
status=ON
fi
done
echo $status
==> openhab.log <==
2021-04-13 20:12:10.520 [INFO ] [core.model.script.CheckAusencia.rule] - >-- It seems that there is no active Mobile. It will be rechecked in a while.
2021-04-13 20:12:30.709 [INFO ] [core.model.script.CheckAusencia.rule] - >-- Value PrensenciaExec before evaluating Phonedet.sh: OFF
2021-04-13 20:12:31.572 [INFO ] [core.model.script.CheckAusencia.rule] - >-- Value PrensenciaExec after evaluating Phonedet.sh: ON
2021-04-13 20:12:31.608 [INFO ] [core.model.script.CheckAusencia.rule] - >-- Confimed nobody at the House
2021-04-13 20:12:31.622 [INFO ] [core.model.script.CheckAusencia.rule] - >-- Switch Post_Presencia OFF
