Hey all,
I’m trying to integrate with a software audio matrix and i’m hitting a bit of a wall. I’ve got it working with the exception of volume, EQ, and mute. 3 pretty important controls for an audio matrix…
The problem with mute is the Json response is true or false but i’d like to be able to just switch it on or off. So I came up with a rule for this that works very well, but I can’t stop thinking it could be easier done (maybe with a transform). Is there an easier way to convert true to on and false to off?
Volume and EQ i’m having the same issue. The response is in hundredths and i’d like it in ones without the decimal. The audio matrix range for vol, bass, mid, and high is 0.01 (0.00 is the same as mute) to 1. 0.50 equals 50%, 0.99 equals 99% and 1 equals 100%. This means all 4 dimmers are always set to 0 and even if I could send a command it would set the zone to 100% no matter what I set the dimmer to. How can I pull in these values, rescale them, and convert from decimal? As if that wasn’t hard enough (for me anyways), to send the command is worse. The rest command is formatted as:
http://192.168.1.190:5050/api/v1/json/SetZoneVolume?zoneName={ZONENAME}&volume={VOLUME}
It’s expecting a specific value for {VOLUME} and it must be in hundredths (0.50 for 50%). I’m not sure how to do this at the item binding level. My guess is i’d have to do it with a rule or a transform and that’s why I created the volume_proxy item, but I’m thinking maybe there’s a better way and in either case i’m not sure how to do it. Any and all help would be greatly appreciated.
The JSON response looks like:
{“AllowedPlayersID”:[],“AudioDevice”:{“DeviceInfo”:{“a”:{“a”:{“value”:9307560},“b”:{“value”:8940376},“c”:1},“driver”:"{0.0.0.00000000}.{d83ba6a8-1a30-4e1f-8531-d3e4c9979f7d}",“flags”:1,“id”:“usb#vid_0d8c&pid_0008&mi_00#6&804d734&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global”,“name”:“Speakers (2- C-Media USB Audio Device )”},“DeviceInfoName”:“Speakers (2- C-Media USB Audio Device )”,“Id”:3,“LatencyMS”:40},“Channels”:16777216,“ID”:“ebbeebae-0b27-47d6-8938-3dbab712b43a”,“Muted”:false,“Name”:“FamilyRoom”,“ParamEQ”:[{“fBandwidth”:18,“fCenter”:100,“fGain”:15},{“fBandwidth”:18,“fCenter”:1000,“fGain”:15},{“fBandwidth”:18,“fCenter”:8000,“fGain”:15}],“Stereo”:false,“Volume”:0.4}
So I created the following in OH:
Items (ignore the extra “>”):
> String Media_AudioZone_ZoneDeck_ID {http="<[http://192.168.1.190:5050/api/v1/json/GetZoneByName?name=Deck:10000:REGEX((.*))]"} > Switch Media_AudioZone_ZoneDeck_Enabled "Deck Zone Power" (gZoneAudioZonesDeck) > String Media_AudioZone_ZoneDeck_Mute "Deck Zone Mute" (gZoneAudioZonesDeck) {http=">[ON:GET:http://192.168.1.190:5050/api/v1/json/SetZoneMute?zoneName=Deck&mute=true] >[OFF:GET:http://192.168.1.190:5050/api/v1/json/SetZoneMute?zoneName=Deck&mute=false]"} > Number Media_AudioZone_ZoneDeck_Volume "Deck Zone Volume" (gZoneAudioZonesDeck) {http="<[http://192.168.90.190:5050/api/v1/json/GetZoneByName?name=Deck:10000:JS(zoneAudioVol.js)] >[*:GET:http://192.168.90.190:5050/api/v1/json/SetZoneVolume?zoneName=Deck&volume=%2$.1f]"} > Number Media_AudioZone_ZoneDeck_Volume_Proxy "Deck Zone Proxy Volume" > Dimmer Media_AudioZone_ZoneDeck_Bass "Deck Zone EQ Bass" (gZoneAudioZonesDeck) > Dimmer Media_AudioZone_ZoneDeck_Mid "Deck Zone EQ Mid" (gZoneAudioZonesDeck) > Dimmer Media_AudioZone_ZoneDeck_High "Deck Zone EQ High" (gZoneAudioZonesDeck)
Transform/zoneAudioVol.js
(function(i) {
var json = JSON.parse(i);
return json[‘Volume’];
})(input)
Rules:
rule "Deck Zone Status"
system started or
Item Media_AudioZone_ZoneDeck_ID received update
Thread::sleep(1000)
var String jsonDeck = (Media_AudioZone_ZoneDeck_ID.state as StringType).toString
var String NameDeck = transform("JSONPATH", "$.Name", jsonDeck)
if (NameDeck == "Deck"){
var String muteDeck = transform("JSONPATH", "$.Muted", jsonDeck)
if(muteDeck == "ture"){
postUpdate(Media_AudioZone_ZoneDeck_Mute, ON)}
else
if(muteDeck == "false"){
postUpdate(Media_AudioZone_ZoneDeck_Mute, OFF)}
