Yes
mosquitto ist kaput!! the mosquitto is dead, we donāt really know what you have been trying to do to get it back up and running so I think itās better that you start from scracth and remove it and re-install it
@Dim, what do you think?
yes , that what i am doing nowā¦ I have purged mosquittoā¦ and following the steps you mentioned in previous threadā¦
There is an open issue with Eclipse with regards to Mosquitto v1.5 on Debian Jessie (most likely this is what Rajeev) is running
If you specify any networking options in the config file: It launches the default plus whatever you defined in your mosquitto.confā¦ causing a conflict and you get:
Error: Address already in use
Some people say that this can be fixed if you upgrade Jessie to Stretch which will update libwebsockets.so
There is no root-cause identified yet and no definite solutionā¦
more info on:
quick question:
I am using below source to download mosquitto. Do you have any other recommendation?
wget https://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
sudo apt-key add mosquitto-repo.gpg.key
sudo wget http://repo.mosquitto.org/debian/mosquitto-stretch.list
sudo -i
sudo apt-get install mosquitto
sudo apt-get install mosquitto-clients
sudo apt-get update
Use the raspberry pi source
You donāt need:
If you did that before you need to remove the repo from the repo list.
Sorry I got ahead of myself
The raspberry pi repository has mosquitto in it
Use that one as it is GUARANTEED to work with your pi
Who told you to install another repository for your rasperry pi is a twit.
Just do:
sudo apt-get update
sudo apt-get upgrade
btw: @rajeev2301 is your Raspbian based on Debian Jessie (8) or Stretch (9)?
output of
lsb_release -a
pi@raspberrypi:~ $ lsb_release -a
|Distributor ID:|Raspbian|
|Description:|Raspbian GNU/Linux 9.4 (stretch)|
|Release:|9.4|
|Codename:|stretch|
sudo apt-get purge mosquitto
sudo reboot
sudo apt-get update
I have reinstalled mosquitto
here is the log OH file and mosquitto log file.
2018-06-01 11:44:32.943 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-06-01 11:44:34.546 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.XX.X.XX:8080
2018-06-01 11:44:34.550 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.XX.X.XX:8443
2018-06-01 11:45:09.155 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'Myhome.items' has errors, therefore i$
2018-06-01 11:45:13.705 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-06-01 11:45:14.899 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'MyHome.things'
2018-06-01 11:45:17.121 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-06-01 11:45:17.311 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-06-01 11:45:17.516 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-06-01 11:45:17.523 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 11:45:17.683 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-06-01 11:45:17.758 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
org.eclipse.paho.client.mqttv3.MqttException: Unable to connect to server
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:79) [205:org.openhab.io.transport.m$
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:650) [205:org.openhab.io.transport.mq$
at java.lang.Thread.run(Thread.java:745) [?:?]
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:?]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:?]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:?]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
at java.net.Socket.connect(Socket.java:589) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:70) ~[?:?]
Mosquitto log file
1527876354: Opening ipv6 listen socket on port 1883.
1527876424: New connection from 127.0.0.1 on port 1883.
1527876424: New client connected from 127.0.0.1 as paho51879022739 (c1, k60).
1527876760: New connection from ::1 on port 1883.
1527876760: New client connected from ::1 as mosqpub|1865-raspberryp (c1, k60, $
1527876760: Client mosqpub|1865-raspberryp disconnected.
1527876777: New connection from ::1 on port 1883.
1527876777: New client connected from ::1 as mosqsub|1876-raspberryp (c1, k60, $
1527876781: New connection from ::1 on port 1883.
1527876781: New client connected from ::1 as mosqpub|1877-raspberryp (c1, k60, $
1527876781: Client mosqpub|1877-raspberryp disconnected.
1527876809: Socket error on client mosqsub|1876-raspberryp, disconnecting.
1527876809: mosquitto version 1.5 terminating
BTW, MQTT.fx is successfully publishing and receiving messages from brokerā¦ Which essentially means mosquitto is working file.
here is output from OH console
openhab> config:property-list
broker.clientId = openhab2
broker.pwd = HomeHub
broker.url = tcp://192.XXX.X.XX:1883
broker.user = username
service.pid = org.openhab.mqtt
Mqtt.cfg please
/etc/openhab2/services/mqtt.cfg
pid:org.openhab.mqtt
broker.url=tcp://192.XX.X.XX:1883
broker.clientId=openhab2
broker.user=username
broker.pwd=HomeHub
I also encountered one strange thing while running mosquitto command from Pi. it is trying to close old connection and opening a new one. plz ref belowā¦
pi@raspberrypi:~ $ mosquitto
1527890040: New connection from 192.XXX.X.XX on port 1883.
1527890040: Client openhab2 already connected, closing old connection.
1527890040: Socket error on client openhab2, disconnecting.
1527890040: New client connected from 192.XXX.X.XX as openhab2 (c1, k60, u'username').
do you have the MQTT Action (not binding) addon installed? (if yes: uninstall it and restart OH2)
also, change the IP of the broker in /etc/openhab2/services/mqtt.cfg
broker.url=tcp://127.0.0.1:1883
broker.pwd=xxxxxx
From what I understand, the Mosquitto Broker is running on the same host as OH2ā¦ correct?
What settings do you use in MQTT.fx
In openhab mqqt.cfg do this:
broker.user= SAME AS MQTT.fx
broker.pwd= SAME AS MQTT.fx
NO , I don;t have any other binding except mqtt
from addons.cfg file.
binding = mqtt1
changed mqtt.cfg
broker.pwd=xxxxxx
yes, MQTT broker is running on the same host as OH2ā¦
Here is the log file after making the above changesā¦
2018-06-01 14:54:00.929 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection los$
2018-06-01 14:54:00.932 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try resto$
2018-06-01 14:54:10.939 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 14:55:10.935 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 14:56:10.936 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 14:57:10.936 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 14:58:10.936 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 14:59:10.935 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 15:00:10.935 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 15:01:10.936 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 15:02:10.936 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 15:03:10.937 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 15:04:10.937 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 15:05:10.936 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 15:06:10.936 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 15:06:54.718 [WARN ] [g.dispatch.internal.ConfigDispatcher] - The file /etc/openhab2/services/mqtt.cfg subsequentl$
2018-06-01 15:06:54.729 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-06-01 15:06:54.734 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 15:07:54.813 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-06-01 15:07:54.813 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
org.eclipse.paho.client.mqttv3.MqttException: MqttException
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:38) [207:org.open$
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:664) [207:org.openhab.io.transp$
Caused by: java.net.SocketTimeoutException: connect timed out
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:650) ~[?:?]
What clientId are you using in MQTT.fx?
I bet 10 EUR he is using the same (openhab2) (or in another device)
@rajeev2301: clientId needs to be unique for every client. Change it from openhab2
to something else in /etc/openhab2/services/mqtt.cfg
By the way: The MQTT Action is not a binding. Check in PaperUI-> Add-Ons ā Actions if it is installed
After changing to 129.0.0.1, MQTT.fx is not able to establish connection with broker. I used Openhab2 as client ID earlierā¦ ( yes, you won 10 Euro). Let me try using another ClientID in MQTT.fx
now MQTT.fx is not connecting to brokerā¦ I have changed the Client ID to openhab and IP address to 172.0.0.1 broker port : 1883, username and password is same and previous.
