switch
(Joseph Rogers)
November 17, 2018, 9:34pm
1
Platform information: Raspberry Pi Nano
Hardware: Raspberry Pi Nano
OS: Rasbian image from openHABian
Java Runtime Environment:Zulu Embedded OpenJDK Java 8
openHAB version: 2.3.0
Issue of the topic: Need help troubleshooting mysql.
I setup mqsql persistence using this guide and it worked great for 10 months and then stopped working.
I see log entries like this:
2018-11-17 13:23:15.027 [WARN ] [sql.internal.MysqlPersistenceService] - mySQL: No connection to database. Cannot persist item ‘HUE_LightLevel_Kitchen (Type=NumberItem, State=20873)’! Will retry connecting to database when error count:0 equals errReconnectThreshold:0
I can access the tables using MySQL workbench. And my config files all look correct. Not sure where to start.
vzorglub
(Vincent Regaud)
November 17, 2018, 9:37pm
2
switch:
Raspberry Pi Nano
You are running openhab2 AND mysql of a raspberry zero?
And it’s fast enough?
Back to your problem
It could be a sign of SD card corruption
Dim
(Angelos)
November 17, 2018, 9:55pm
3
no changes happened during these 10 months? (btw: OH 2.3.0 Stable or another release?)
where is your mysql server? on localhost or across the LAN?
post your mysql.cfg
, enable DEBUG on the persistence service addon from the console and monitor openhab.log
log:set DEBUG org.openhab.persistence.mysql
check also for free space on your SD Card (just in case): df -h
switch
(Joseph Rogers)
November 17, 2018, 10:20pm
4
MySQL is running on same host as OpenHab (OH 2.3.0)
# the database url like 'jdbc:mysql://<host>:<port>/<database>' (without quotes)
url=jdbc:mysql://127.0.0.1:3306/OpenHAB
#url=jdbc:mysql://127.0.0.1/OpenHAB
# the database user
user=openhab
# the database password
password=********
# the reconnection counter
#reconnectCnt=
# the connection timeout (in seconds)
#waitTimeout=
# Use MySQL Server time to store item values (=false) or use openHAB Server time (=true).
# For new installations, its recommend to set "localtime=true".
# (optional, defaults to false)
#localtime=true
root@raspberrypi:/var/log/openhab2# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 5.9G 4.6G 1.1G 82% /
devtmpfs 213M 0 213M 0% /dev
tmpfs 218M 0 218M 0% /dev/shm
tmpfs 218M 8.9M 209M 5% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 218M 0 218M 0% /sys/fs/cgroup
/dev/mmcblk0p6 66M 21M 45M 32% /boot
tmpfs 44M 0 44M 0% /run/user/1000
/dev/mmcblk0p5 30M 398K 28M 2% /media/pi/SETTINGS3
Dim
(Angelos)
November 17, 2018, 10:21pm
5
config file looks good
enable debug and check log entries
switch
(Joseph Rogers)
November 17, 2018, 11:34pm
6
OK, figured this out. The password some how changed. Once I set to what was in the mysql.cfg, things started working.
