Thanks, I really had the open hab designer.
Now I have installed the eclipse, but it won´t start. I took the 64bit und the 64bit Java.
Here is the log, I don´t know what´s the Problem:
!SESSION 2016-11-16 14:44:09.021 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.equinox.ds 1 0 2016-11-16 14:44:09.500
!MESSAGE Could not bind a reference of component ConfigDescriptionRegistry. The reference is: Reference[name = ConfigOptionProvider, interface = org.eclipse.smarthome.config.core.ConfigOptionProvider, policy = dynamic, cardinality = 0…n, target = null, bind = addConfigOptionProvider, unbind = removeConfigOptionProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2016-11-16 14:44:09.504
!MESSAGE Could not bind a reference of component ConfigDescriptionRegistry. The reference is: Reference[name = ConfigDescriptionProvider, interface = org.eclipse.smarthome.config.core.ConfigDescriptionProvider, policy = dynamic, cardinality = 0…n, target = null, bind = addConfigDescriptionProvider, unbind = removeConfigDescriptionProvider]
!ENTRY org.eclipse.update.configurator 4 0 2016-11-16 14:44:10.148
!MESSAGE Could not install bundle plugins/ch.qos.logback.classic_1.0.7.v20121108-1250.jar A bundle is already installed with the name “ch.qos.logback.classic” and version “1.0.7.v20121108-1250”
!ENTRY org.eclipse.update.configurator 4 0 2016-11-16 14:44:10.154
!MESSAGE Could not install bundle plugins/ch.qos.logback.core_1.0.7.v20121108-1250.jar A bundle is already installed with the name “ch.qos.logback.core” and version “1.0.7.v20121108-1250”
!ENTRY org.eclipse.update.configurator 4 0 2016-11-16 14:44:10.161
!MESSAGE Could not install bundle plugins/ch.qos.logback.slf4j_1.0.7.v20121108-1250.jar A bundle is already installed with the name “ch.qos.logback.slf4j” and version “1.0.7.v20121108-1250”
!ENTRY org.eclipse.equinox.ds 1 0 2016-11-16 14:44:11.384
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.core.thing.firmware.FirmwareUpdateService. The reference is: Reference[name = FirmwareUpdateHandler, interface = org.eclipse.smarthome.core.thing.binding.firmware.FirmwareUpdateHandler, policy = dynamic, cardinality = 0…n, target = null, bind = addFirmwareUpdateHandler, unbind = removeFirmwareUpdateHandler]
!ENTRY org.eclipse.equinox.ds 1 0 2016-11-16 14:44:11.439
!MESSAGE Could not bind a reference of component org.eclipse.smarthome.model.thing.internal.genericthingprovider. The reference is: Reference[name = ThingHandlerFactory, interface = org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, policy = dynamic, cardinality = 0…n, target = null, bind = addThingHandlerFactory, unbind = removeThingHandlerFactory]
!ENTRY org.eclipse.osgi 4 0 2016-11-16 14:44:11.593
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: The platform metadata area could not be written: C:\Program Files (x86)\Smarthomedesigner\workspace.metadata. By default the platform writes its content
under the current working directory when the platform is launched. Use the -data parameter to
specify a different content area for the platform.
at org.eclipse.core.internal.runtime.DataArea.assertLocationInitialized(DataArea.java:61)
at org.eclipse.core.internal.runtime.DataArea.getStateLocation(DataArea.java:129)
at org.eclipse.core.internal.preferences.InstancePreferences.getBaseLocation(InstancePreferences.java:44)
at org.eclipse.core.internal.preferences.InstancePreferences.initializeChildren(InstancePreferences.java:199)
at org.eclipse.core.internal.preferences.InstancePreferences.(InstancePreferences.java:59)
at org.eclipse.core.internal.preferences.InstancePreferences.internalCreate(InstancePreferences.java:209)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:391)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:379)
at org.eclipse.core.internal.preferences.PreferencesService.createNode(PreferencesService.java:389)
at org.eclipse.core.internal.preferences.RootPreferences.getChild(RootPreferences.java:63)
at org.eclipse.core.internal.preferences.RootPreferences.getNode(RootPreferences.java:101)
at org.eclipse.core.internal.preferences.RootPreferences.node(RootPreferences.java:90)
at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:38)
at org.eclipse.core.runtime.preferences.InstanceScope.getNode(InstanceScope.java:80)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getStorePreferences(ScopedPreferenceStore.java:244)
at org.eclipse.ui.preferences.ScopedPreferenceStore.(ScopedPreferenceStore.java:133)
at org.eclipse.ui.plugin.AbstractUIPlugin.getPreferenceStore(AbstractUIPlugin.java:285)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:593)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at org.eclipse.smarthome.designer.ui.internal.application.Application.start(Application.java:32)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
