Need help with fingerbot on zigbee2mqtt
I have this tuya device
the only thing I can control successfully is ON/OFF state.
Cannot read/write any other property, even battery state.
EDIT: just checked, I can also read linkquality property (its 23)
I would like to adjust upper and lower limits, as its pressing the button too strong and burning the battery too fast
THINGS:
    Thing topic Fingerbot "Fingerbot" @ "Living Room"
        Channels:
            Type switch : state "state" [ stateTopic = "zigbee2mqtt/Fingerbot/state", commandTopic = "zigbee2mqtt/Fingerbot/set" ]
            Type number : battery "battery" [ stateTopic = "zigbee2mqtt/Fingerbot/battery" ]
            Type number : linkquality "linkquality" [ stateTopic = "zigbee2mqtt/Fingerbot/linkquality" ]
            Type string : mode "mode" [ stateTopic = "zigbee2mqtt/Fingerbot/mode", commandTopic = "zigbee2mqtt/Fingerbot/set" ]
            Type number : upper "Fingerbot Upper %d %%" [ stateTopic = "zigbee2mqtt/Fingerbot/upper", commandTopic = "zigbee2mqtt/Fingerbot/set", min=0, max=50, step=1 ]
            Type number : lower "lower" [ stateTopic = "zigbee2mqtt/Fingerbot/lower", commandTopic = "zigbee2mqtt/Fingerbot/set", min=0, max=100, step=1 ]
ITEMS:
Switch Fingerbot          "Fingerbot [%s]"  <button>   {channel="mqtt:topic:mosquitto:Fingerbot:state"}
Number FingerbotBattery   "Fingerbot Battery [%.1f %%]"  <battery> (gBattery)   {channel="mqtt:topic:mosquitto:Fingerbot:battery"}
String FingerbotMode      "Fingerbot Mode [%s]"  <button>   {channel="mqtt:topic:mosquitto:Fingerbot:mode"}
Number Fingerbot_Link     "Fingerbot Link [%d %%]"    {channel="mqtt:topic:mosquitto:Fingerbot:linkquality"}
Number FingerbotUpper     "Fingerbot Upper [%d %%]"   {channel="mqtt:topic:mosquitto:Fingerbot:upper"}
Number FingerbotLower     "Fingerbot Lower1 [%d %%]"  {channel="mqtt:topic:mosquitto:Fingerbot:lower"}
do you see any mistake in the config? thanks
