Hello guys,
i installed openHABien and configured it with this instructions: openHABian hassle-free openHAB Setup
it works very well but homegear can`t connect to HM-MOD-RPI-PCB.
This is the homgear log:
/var/log/homegear/homegear.log
03/03/17 21:17:44.420 Starting Homegear...
03/03/17 21:17:44.420 Homegear version 0.6.19-956
03/03/17 21:17:44.420 Git commit SHA of libhomegear-base: -
03/03/17 21:17:44.420 Git branch of libhomegear-base: -
03/03/17 21:17:44.421 Git commit SHA of Homegear: -
03/03/17 21:17:44.421 Git branch of Homegear: -
03/03/17 21:17:44.421 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
03/03/17 21:17:44.421 Info: Core file size now is "4294967295".
03/03/17 21:17:44.422 Info: Setting maximum thread priority to "4294967295" for user with id 0 and group with id 0.
03/03/17 21:17:44.422 Info: Maximum thread priority now is "4294967295".
03/03/17 21:17:44.426 Info: Backing up database...
03/03/17 21:17:44.758 Initializing database...
03/03/17 21:17:44.761 Info: Loading family module mod_homematicbidcos.so
03/03/17 21:17:44.773 /etc/homegear/families/homematicbidcos.conf
03/03/17 21:17:44.774 Info: Loading family module mod_homematicwired.so
03/03/17 21:17:44.780 /etc/homegear/families/homematicwired.conf
03/03/17 21:17:44.781 Info: Loading family module mod_miscellaneous.so
03/03/17 21:17:44.784 /etc/homegear/families/miscellaneous.conf
03/03/17 21:17:44.784 Info: Setting up physical interfaces and GPIOs...
03/03/17 21:17:44.785 Info: Dropping privileges to user homegear (110) and group homegear (116)
03/03/17 21:17:44.786 Info: Homegear is (now) running as user with id 110 and group with id 116.
03/03/17 21:17:44.786 Starting script engine server...
03/03/17 21:17:44.820 Initializing licensing controller...
03/03/17 21:17:44.821 Loading licensing controller data...
03/03/17 21:17:44.821 Loading devices...
03/03/17 21:17:44.821 Loading XML RPC devices...
03/03/17 21:17:45.842 Loading device 2
03/03/17 21:17:45.842 Module HomeMatic BidCoS: Info: Central address set to 0xFD2AB5.
03/03/17 21:17:45.843 Info: Not initializing device family HomeMatic Wired, because no physical interface was found.
03/03/17 21:17:45.843 Info: Disposing family module mod_homematicwired.so
03/03/17 21:17:45.844 Loading XML RPC devices...
03/03/17 21:17:45.846 Loading device 1
03/03/17 21:17:45.846 Start listening for packets...
03/03/17 21:17:47.847 Initializing RPC client...
03/03/17 21:17:47.847 Starting XML RPC server RPCServer1 listening on :::2001...
03/03/17 21:17:47.849 Starting XML RPC server RPCServer2 listening on :::2002, SSL enabled...
03/03/17 21:17:47.850 RPC Server (Port 2001): Info: RPC Server started listening on address :: and port 2001
03/03/17 21:17:47.882 Starting XML RPC server RPCServer3 listening on :::2003, SSL enabled, authentication enabled...
03/03/17 21:17:47.882 RPC Server (Port 2002): Info: RPC Server started listening on address :: and port 2002
03/03/17 21:17:47.914 Starting CLI server...
03/03/17 21:17:47.914 RPC Server (Port 2003): Info: RPC Server started listening on address :: and port 2003
03/03/17 21:17:47.914 Initializing event handler...
03/03/17 21:17:47.915 Starting flows server...
03/03/17 21:17:47.917 Startup complete. Waiting for physical interfaces to connect.
03/03/17 21:17:47.917 All physical interfaces are connected now.
03/03/17 21:17:47.917 Starting UPnP server...
03/03/17 21:17:47.919 Info: UPnP server: Binding to address: 192.168.2.115
03/03/17 21:17:47.919 UPnP Server: Info: Started listening.
03/03/17 21:18:17.947 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
03/03/17 21:18:19.862 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
03/03/17 21:18:21.863 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
03/03/17 21:18:51.964 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
03/03/17 21:18:57.892 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
03/03/17 21:18:59.893 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
03/03/17 21:19:29.994 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
03/03/17 21:19:35.928 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
03/03/17 21:19:37.929 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
03/03/17 21:20:07.797 Info: CLI connection accepted. Client number: 17
03/03/17 21:20:08.030 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
03/03/17 21:20:13.963 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
03/03/17 21:20:15.965 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
03/03/17 21:20:46.065 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
03/03/17 21:20:52.000 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
03/03/17 21:20:54.001 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
Does anyone know what “Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Error: No init packet received.” means?
