Need help with logger configuration
I added to my /var/lib/openhab/etc/log4j2.xml
<!-- Zwave custom file appender -->
		<RollingRandomAccessFile fileName="${sys:openhab.logdir}/zwave.log" filePattern="${sys:openhab.logdir}/zwave.log.%i" name="ZWAVE">
			<PatternLayout pattern="%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n"/>
			<Policies>
				<OnStartupTriggeringPolicy/>
				<SizeBasedTriggeringPolicy size="16 MB"/>
			</Policies>
		</RollingRandomAccessFile>
and added
org.openhab.binding.zwave                          │ DEBUG
to the karaf configuration…
But it still gets logged into the normal openhab.log file…What is wrong?
There is a working example in the docs:
Yes I copied the configuration from there…But the zwave log stays empty
No, you are missing the Loggers section …
Thank zou :slight_smile:
