Need help with rules on OH2
rules
openhab2
Tags: #<Tag:0x00007f1e669a7140> #<Tag:0x00007f1e669a6678>
(Clint Sutherland) #1
Hi folks.
Newbie to openhab.
I installed it 2x weeks ago, the latest running 2.4.0 and installed in Raspberry Pi3.
I’m using Paper UI and HABPanel.
I’ve been doing a lot of reading over the last 2x weeks and seeing contradictory information shared by users.
I see a lot of scripting references for Items, Rules, Cfg etc. and some users say that these are not required when using OH2 and MQTT2.4 since all config can be done via GUI.
I tried some examples as per many available on forums, but I always get an error in the OH log. They typically mention “no EOF” etc.
I’ve installed MQTT 2.4 and not familiar with any scripting.
After several days, I managed to get my Sonoff loaded with Tasmota to work to my OH2.
I have several Sonoff devices which includes BASIC, DUAL, RF Bridge and some PIR motion detectors.
I required to switch on a Sonoff BASIC when the PIR detects motion at night.
But it needs to switch off after several minutes, example 15min.
I don’t know how to achieve this via GUI.
So, the following is my setup…
I’m going to use a T1 light switch to control an outside light, but for this exercise to learn how to create this, I’ll be using a Sonoff BASIC.
The following is what my THINGS look like for the RF Bridge:
The detailed setup for above channel is:
What I’m achieving here is this: when the RF Bridge receives a 433MHz signal I extract the “data” portion as this is unique for any transmitter.
I then turn this received “data” into a command.
Here is an example of captured data when the PIR acts on motion and transmits to the RF Bridge:
Once above is received, I then run a rule. The rule then looks for a command to match and then performs on this action.
So, here is the rule:
The following is the actual TRIGGER:
The following is the action, if TRIGGER matches:
The following is currently the only condition, i.e. it will only work in the evening:
The GUI offers no method for timing.
(Rossko57) #2
This might offer an intro to GUI rules (aka NGRE)
As of 2.4, it doesn’t offer any useful timing features.
There are other methods to construct rules, you’l have seen examples of the text based xxx.rules files.
(Clint Sutherland) #3
Hi Rossko.
Ok, thanks for the link. Spent some tonight on it tonight…
I’ve installed the JSR223 libs etc.
A lot of js scripts included, but can’t make head or tails from the contents.
I then tried the do the following:
From above original posting, I showed my single rule in place for the moment created via Paper UI.
I then updated the this rule to include an additional “then” function.
The first “then” triggers a Sonoff Basic to switch on, this is simulating my lights.
The second “then” is suppose to start a script.
The contents of this script contains a TIMER function which will then switch off the lights after some time.
See here the setup:
This shows the 2x “then” in UI.
This shows the setup inside the “then” to start the script.
I don’t know if this format is correct or path is correct.
This shows the actual contents of the script. This copied from some examples found.
But when I trigger the event, the light switches on…but the script event is not working and getting the following error on log:
Clearly a lot of things I don’t understand.
(Rossko57) #4
Looks like you found an example in the text files “DSL” syntax. The vast majority of examples will be. Don’t think that’s going to work by putting it in an xxx.py file where it expects python syntax.
(Clint Sutherland) #5
Hi Rossko.
Sure. Before the xxx.py, I tried xxx.js but same issue.
(Clint Sutherland) #6
So from online reading…I installed the JSR223 info…
I’m pretty sure that the scripting required must be presented in java format and the script file should be inside JSR223 folder.
Looking at the examples included, I guess the following is the closest to my needs for this topic:
 * Copyright (c) 2018 by Helmut Lehmeyer.
 * @author Helmut Lehmeyer
'use strict';
load(Java.type("java.lang.System").getenv("OPENHAB_CONF")+'/automation/jsr223/jslib/JSRule.js');
var me = "TimerExample.js";
logInfo("################# "+me+" ##################");
JSRule({
	name: me+" TimerExample",
	description: "TimerExample L:"+__LINE__,
	triggers: [
		TimerTrigger("0/15 * * * * ?")
	execute: function( module, input){
		logInfo("################ "+me+" Line: "+__LINE__+"  #################");
		logInfo( "createTimer start");
		createTimer(DateTime.now().plusSeconds(2), function(){
			logWarn( "createTimer stopped ");
		logInfo( "setTimeout start");
		setTimeout(function(m){
			logWarn( "setTimeout stopped " + m);
		}, 1000, "bla");
But from above, not clear what I can substitute for my own ITEM.
(Clint Sutherland) #7
Dear folks.
Some catchup since previous post.
I’ve abandoned the rule concept via Java scripting and what else.
I don’t understand…
Having this said…I took a fresh approach to text file (so I will refer to this as plain scripting).
I mentioned in first post I tried this but always had a constant error showing up in Openhab log.
I went back to those errors and searched some on that and actually found numerous references to this…
So, the problem was with " - quotes…my text editor would use non-standard quotes and this would be a continuous problem…
So, now that I had that resolved I could move on and focus on other steps…
Which I managed well actually, considering spending many hours on them this past week with a lot of reading on posts etc.
Ok, let’s check my original intention with this particular rule required.
I want an outside light to switch on which is at my front door.
The light should only switch on when presence/movement is detected after hours.
It should stay on for a determined time.
Here is what I managed to get working successfully:
//Rule to switch on outside left light after hours
var Timer MotionTimer = null
rule “Entrance left light timer”
Item GenericMQTTThing_RFBridgeRX received command EC65BE
logInfo(“Outside Left Light Timer Function”, “Outside passage motion detected!”)
GenericMQTTThing_UrnSwitch.sendCommand(ON)
  if(MotionTimer !== null) {
    MotionTimer.reschedule(now.plusSeconds(10))
  else {
	    MotionTimer = createTimer(now.plusSeconds(10)) [ |
	    GenericMQTTThing_UrnSwitch.sendCommand(OFF)
	    MotionTimer = null
        logInfo("Outside Left Light", "Switched off!")
}end
The ITEM triggers when a specific code is received.
It then logs INFO to openhab log, then switches on the light (I’m using a Sonoff Basic for testing).
After 10 seconds it switches off. In real life this will be changed to something like 15min.
If during the ON time, it triggers again, then the timer get updated (extended).
Once the light switches off, then again it logs the activity to openhab log.
So, very happy with this first setup.
I would like to add a “IF” to this to ensure this will only happen at night though…
But I’ll look at this later.
Now…i have another rule I built.
Similar to above…this rule will monitor my gate (gate to my driveway).
When the gate opens at night, it should again switch on some light.
In fact, I need this to switch on 2x lights.
I’m thinking of using GROUP to do this…but later though…
My first issue is the following:
The below script is working fine for testing where the gate opening is detected and the light switches on and after the timer runs out, the light switches off.
I then added a routine to check for hours…meaning I only want the lights to switch on if after hours.
When I added this…very little works…I don’t know how else to write the script.
I don’t understand how to place/write the IF…THEN inside another IF…THEN.
//Rule to switch on both left and right front lights when the gate opens after hours
var Timer GateTimer = null
rule “Gate Light Timer”
Item GenericMQTTThing_RFBridgeRX received command AC2B99
logInfo(“Driveway gate”, “Gate moving!”)
if (now.getHourOfDay() >= 6 && now.getHourOfDay() < 23) {
	GenericMQTTThing_WallFountain.sendCommand(ON)  [ |
	logInfo("All Front Outside Lights", "Switched on!")
    	GateTimer = createTimer(now.plusSeconds(10)) [ |
		GenericMQTTThing_WallFountain.sendCommand(OFF)
		GateTimer = null
    	logInfo("Outside Light", "Switched off!")
	else   {
}end
Could someone guide me in above?
(Rossko57) #8
Okay, it may seem old fashioned in the face of fancy GUIs but there are more examples and it’s easier to share work, a good place to start out :smiley:
In this rules language, there is no if-then, or more precisely no then keyword in an if().
You didn’t use it in your rule that works.
then is strictly to divide rule trigger from rule body.
if (condition) {
    // do stuff
if (condition) {
    // do stuff
} else {
    // do other stuff
if (condition) {
   // do stuff
    if (other condition) {
        // do other stuff
    // do more stuff
Indenting is not needed for it to work, it’s for you to keep your sanity working out which block belongs to which if
(Clint Sutherland) #9
Hi Rich.
Thanks for above comments.
Did some more work and added the actual Sonoff light switches.
Below is my script when the gate is opening I have 2x sets of lights coming soon.
They have been added to a group and I control the group from this rule.
This works 100% for me.
This triggers only after hours, and the timer is a once of 15min cycle.
The rule currently still shows with a 10sec though for testing.
if (now.getHourOfDay() >= 17 && now.getHourOfDay() < 23) {
	Welcomelights.sendCommand(ON)
	Welcomelights.sendCommand(OFF)
	GateTimer = null
(Clint Sutherland) #10
The next rule is when someone walks in the outside corridor leading up to the front door.
This rule has been updated with the actual Sonoff light switch.
It contains a timer and timer will also reset if PIR has been triggered multiple times causing the lights to stay on linger before switching off.
The only thing missing here…still don’t know how to add this…it to ensure this rule only works after hours.
logInfo(“Outside Left Light”, “Outside passage motion detected!”)
GenericMQTTThing_LeftFrontOutsideLight.sendCommand(ON)
  else {
	    GenericMQTTThing_LeftFrontOutsideLight.sendCommand(OFF)
	    MotionTimer = null
}end
(Rossko57) #11
Is there a reason you haven’t tried wrapping the whole rule body in an
    // trigger
   if (hours condition) {
       // existing rules stuff
exactly like you already did for the gate rule?
(Clint Sutherland) #12
Hi Rich.
Yes I did try this…however…the problem then is the timer reset, or timer reschedule.
I don’t know how to reset/reschedule the timer if timer already running and another motion is detected in the meantime so that the timer value can be extended.
(Rossko57) #13
You’re already doing that in the rule you showed us. On motion, it reschedules if the timer is already running, or creates a new timer if not.
If its not in-hours, you need do nothing.
