Hi guys,
i want to be able to set desired roomtemperatures on my Moelenhoff Alpha 2.
Here you see the documentation (german, sry
Alpha2-XML-Schnittstellenbeschreibung_de.pdf (475.5 KB)
Sorry for reposting my problem, but in the other threat i found, nobody seems to recocnize it.
As far as i understand (newbie), the temperatures can be set via an xml and with the help of the http-binding.
I tried, what shorty707 posted here: Möhlenhoff Alpha BUS - Solution
Unfortunateley it does not work. I am sure, i made a mistake somewhere but i am not able to find it.
As far as i understand the Moelenhoff documentation, this is, what should be posted to http://192.168.178.22/data/changes.xml when setting the temp i.e. to 20.6.
Here all i have done:
Running on OH 3.2.0
JSONtransformation service is installed
Log gives me an error i dont understand. „in 25.0“ is the value, i tried to set via the sitemap.
2022-08-26 22:02:56.250 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='Alpha2_FBH_WC.js', serviceName='JSONPATH'} failed: Invalid path 'Alpha2_FBH_WC.js' in '25.0'
EDIT: I changed the channel and linked item to STRING. Now, i dońt get the error anymore. But still the tempvalue in the Moelenhoff UI does not change.
Thing/Chanels:
UID: http:url:d85bf36e84
label: TestHeizungSet
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: false
baseURL: http://192.168.178.22/data/changes.xml
delay: 0
stateMethod: GET
refresh: 30
commandMethod: POST
contentType: application/xml
timeout: 3000
bufferSize: 2048
channels:
- id: TestSetTempWC
channelTypeUID: http:number
label: Test Set Temp WC
description: ""
configuration:
mode: WRITEONLY
commandTransformation: JSONPATH:Alpha2_FBH_WC.js
I put a scriptfile into the transformation folder. Here i am not sure, everything is right.
I created a textfile called Alpha2_FBH_WC.js. Here the content:
(function(i) {
var str1 = "<?xml version=\"1.0\" encoding=\"UTF-8\"?> <Devices> <Device> <ID>HKV147</ID> <HEATAREA nr=\"8\"> <T_TARGET>";
var str3 = "</T_TARGET> </HEATAREA> </Device> </Devices>";
result = str1 + i + str3;
return result;
})(input)
Thank you for everything
