Hi all, I’m trying to draw a widget like this for thermostat settings, and a bit out of ideas/knowledge how to achieve the same result with f7-framework and css. What I’ve got so far is something like
Widget code is
uid: Cell_Temp_Card_Expanded
tags:
- co
- humidity
- motion
- temperature
props:
parameters:
- description: Title on top of the card
label: Title
required: false
type: TEXT
- description: Icon on top of the card (only f7 icons (without f7:))
label: Icon
required: false
type: TEXT
- description: Background image name
label: Background image
required: false
type: TEXT
- description: in rgba() or HEX or empty
label: Background Color
required: false
type: TEXT
- context: item
label: Temperature
required: false
type: TEXT
- context: item
label: Target Temperature
required: false
type: TEXT
- context: item
label: Cooling On/Off
required: false
type: TEXT
- context: item
label: Heating On/Off
required: false
type: TEXT
- context: item
label: Lightlevel
required: false
type: TEXT
- context: item
label: Humidity
required: false
type: TEXT
- context: item
label: Target Humidity
required: false
type: TEXT
- context: item
label: Humidifier On/Off
required: false
type: TEXT
- context: item
label: Fanspeed
required: false
type: TEXT
- context: item
label: Fan on/off
required: false
type: TEXT
- context: item
label: Humidifier fan speed
required: false
type: TEXT
- context: item
label: CO
required: false
type: TEXT
- context: item
label: Motion item
required: false
type: TEXT
- context: item
label: Lights group
required: false
type: TEXT
- context: item
label: Door item
required: false
type: TEXT
- context: item
label: Lock item
required: false
type: TEXT
- context: item
label: Window item
required: false
type: TEXT
- context: item
label: Leakage item
required: false
type: TEXT
- context: item
label: Smoke item
required: false
type: TEXT
- context: item
label: Media Title
required: false
type: TEXT
- context: item
label: Power Item
required: false
type: TEXT
- context: item
label: Channel
required: false
type: TEXT
- context: item
label: Key Code
required: false
type: TEXT
- context: item
label: Volume Control Item
required: false
type: TEXT
- context: item
label: Source Name
required: false
type: TEXT
parameterGroups: []
timestamp: Feb 5, 2023, 7:57:31 PM
component: f7-card
hideNavbar: true
style:
--f7-badge-text-color: var(--f7-text-color)
--f7-bars-border-color: none
--f7-bars-translucent-blur: none
--f7-bars-translucent-opacity: none
--f7-navbar-bg-color: transparent
--f7-navbar-border-color: transparent
--f7-navbar-link-color: var(--f7-text-color)
--f7-page-navbar-offset: none
--f7-bars-bg-color: transparent
--f7-page-content-extra-padding-bottom: none
--f7-page-content-extra-padding-top: none
--f7-page-searchbar-offset: none
--f7-page-subnavbar-offset: none
--f7-page-toolbar-bottom-offset: none
--f7-page-toolbar-top-offset: none
background: transparent
background-brightness: 60%
background-color: "=props.bgcolor ? props.bgcolor : ''"
background-image: "=props.bg_image_url ? 'url(/static/' + (props.bg_image_url) + ')' : ''"
background-position: down
background-repeat: no-repeat
background-size: cover
box-shadow: 5px 5px 10px 1px var(--f7-card-bg-color)
font-size: large
font-weight: 700
height: 100%
margin: 0
noShadow: false
overflow: hidden
text-shadow: -0.006em -0.006em 0.18em var(--f7-card-bg-color)
stylesheet: >
.range-knob {
width: 150px;
height: 80px;
translate: -50% -62%;
clip-path: path('M74.3132 0C47.0043 2.44032e-05 50.175 30 7.9179 30H144.27C99.4571 30 101.622 -2.44032e-05 74.3132 0Z');
slots:
default:
- component: f7-card-header
style:
display: flex
justify-content: center
margin: 0
min-height: 35px
padding: 0
slots:
default:
- component: f7-icon
f7: =props.icon
visible: "=props.icon ? true : false"
- component: Label
style:
font-size: 20px
font-weight: bold
margin-left: 5px
text: "=props.title ? props.title : ''"
- component: f7-card-content
style:
margin: 0
padding: 0
slots:
default:
- component: f7-row
slots:
default:
- component: f7-segmented
color: gray
raised: false
strong: true
style:
backdrop-filter: blur(5px)
width: 100%
slots:
default:
- component: oh-button
action: variable
actionVariable: select
actionVariableValue: 1
active: =(vars.select == 1)
iconF7: thermometer
iconSize: 40
large: true
outline: =(vars.select == 1)
style:
height: 45px
action: variable
actionVariableValue: 2
active: =(vars.select == 2)
iconF7: thermometer_snowflake
iconSize: 40
large: true
outline: =(vars.select == 2)
style:
height: 45px
visible: "=props.temperatureset_item || props.humidityset_item || props.fanon_item || props.coolingon_item || props.heatingon_item ? true : false"
action: variable
actionVariableValue: 3
active: =(vars.select == 3)
iconF7: film
iconSize: 40
large: true
outline: =(vars.select == 3)
style:
height: 45px
visible: "=props.power ? true : false"
action: variable
actionVariableValue: 4
active: =(vars.select == 4)
iconF7: shield
iconSize: 40
large: true
outline: =(vars.select == 4)
style:
height: 45px
visible: "=props.lock_item || props.door_item || props.window_item || props.motion_item || props.leakage_item ? true : false"
action: variable
actionVariableValue: 5
active: =(vars.select == 5)
iconF7: graph_square
iconSize: 40
large: true
outline: =(vars.select == 5)
style:
height: 45px
- component: f7-tab
class:
- display-flex
- justify-content-space-between
- flex-direction-column
style:
animation: f7-fade-in 300ms
margin: 5px
padding: 0px
visible: =(vars.select == 1 || vars.select == NULL)
slots:
default:
- component: f7-row
style:
border-bottom: 1px solid
filter: drop-shadow(0px 0px 1px var(--f7-card-bg-color))
margin: 10px
slots:
default:
- component: f7-col
style:
width: auto
user-select: none
pointer-events: none
slots:
default:
- component: f7-row
style:
flex-wrap: nowrap
justify-content: flex-start
visible: "=props.temp_item ? true : false"
slots:
default:
- component: oh-icon
icon: martinitemp
state: =items[props.temp_item].state
width: 30
- component: Label
style:
color: '=(Number.parseFloat(items[props.temp_item].state.split(" ")[0]) > 30) ? "rgb(242,75,36)" : (Number.parseFloat(items[props.temp_item].state.split(" ")[0]) < 10) ? "rgba(32, 185, 256,0.8)" : "var(--f7-text-color)"'
margin-left: 5px
text: =items[props.temp_item].state.split(" ")[0]+" °C"
- component: f7-row
style:
flex-wrap: nowrap
z-index: 2
visible: "=props.humidity_item ? true : false"
slots:
default:
icon: hum
state: =items[props.humidity_item].state
width: 30
- component: Label
style:
color: '=(Number.parseFloat(items[props.humidity_item].state.split(" ")[0]) < 35) ? "rgb(242,75,36)" : (Number.parseFloat(items[props.humidity_item].state.split(" ")[0]) > 75) ? "green" : "var(--f7-text-color)"'
margin-left: 5px
text: =items[props.humidity_item].state.split(" ")[0]+" %"
- component: f7-row
style:
flex-wrap: nowrap
z-index: 2
visible: "=props.lightlevel_item ? true : false"
slots:
default:
icon: lightlevel
state: =items[props.lightlevel_item].state
width: 30
- component: Label
style:
color: "=(items[props.lightlevel_item].state < 1) ? 'gray' : 'var(--f7-text-color)'"
margin-left: 5px
text: =items[props.lightlevel_item].state.split(" ")[0]+" lux"
- component: f7-row
style:
flex-wrap: nowrap
z-index: 2
visible: "=props.CO_item ? true : false"
slots:
default:
icon: carbondioxidecloud
state: =items[props.CO_item].state
width: 30
- component: Label
style:
color: '=(Number.parseFloat(items[props.CO_item].state.split(" ")[0]) > 1500) ? "red" : (Number.parseFloat(items[props.CO_item].state.split(" ")[0]) > 1000) ? "rgb(242,75,36)" : "var(--f7-text-color)"'
margin-left: 5px
white-space: nowrap
text: =items[props.CO_item].state.split(" ")[0]+" ppm"
- component: f7-col
style:
align-items: center
display: flex
flex-direction: column
justify-content: flex-end
width: auto
slots:
default:
- component: f7-col
style:
z-index: 1
visible: "=props.motion_item || props.lock_item ? true : false"
slots:
default:
action: analyzer
actionAnalyzerItems: =[props.motion_item]
large: true
visible: "=props.motion_item ? true : false"
slots:
default:
icon: f7:dot_radiowaves_left_right
style:
color: '=(items[props.motion_item].state == "ON") ? "red" : "var(--f7-text-color)"'
width: 40
action: toggle
actionCommand: ON
actionCommandAlt: OFF
actionItem: =[props.lock_item]
large: true
visible: "=props.lock_item ? true : false"
slots:
default:
icon: "=(items[props.lock_item].state === 'ON') ? 'f7:lock' : 'f7:lock_open'"
style:
width: 30
- component: f7-col
style:
z-index: 1
visible: "=props.door_item || props.window_item ? true : false"
slots:
default:
icon: "=(items[props.door_item].state === 'ON') ? 'door-closed' : 'door-open'"
visible: "=props.door_item ? true : false"
width: 25
icon: "=(items[props.window_item].state === 'ON') ? 'window' : 'window-open'"
visible: "=props.window_item ? true : false"
width: 25
- component: f7-block
style:
margin: 5px
padding: 0px
slots:
default:
- component: oh-repeater
fetchMetadata: semantics,metadata
filter: '(loop.switchItem.type=="Switch") ? true : false'
for: switchItem
groupItem: =props.light
sourceType: itemsInGroup
slots:
default:
- component: f7-row
style:
margin-bottom: 5px
slots:
default:
actionItem: =loop.switchItem.name
action: toggle
actionCommand: ON
text: =loop.switchItem.label
iconF7: '=(items[loop.switchItem.name].state == "ON") ? "lightbulb_fill" : "lightbulb"'
iconSize: 35
round: true
style:
padding: 0
backdrop-filter: blur(2px)
width: calc(100% - 85px)
height: 2.1em
line-height: 1.9em
text-align: start
--f7-button-bg-color: transparent
--f7-button-text-color: var(--f7-text-color)
--f7-button-font-size: 1em
--f7-button-hover-bg-color: transparent
- component: oh-toggle
color: yellow
item: =loop.switchItem.name
style:
--f7-toggle-height: 35px
--f7-toggle-inactive-color: rgba(100,100,100,0.8)
--f7-toggle-width: 75px
filter: '(loop.dimmerItem.type=="Dimmer") ? true : false'
for: dimmerItem
slots:
default:
- component: f7-row
style:
margin-left: 5px
margin-bottom: 5px
align-items: center
font-size: 1em
slots:
default:
height: 30
icon: f7:sun_max
style:
z-index: 2
user-select: none
color: '=(loop.dimmerItem.state == "ON") ? "yellow" : var(--f7-text-color)'
- component: Label
style:
z-index: 2
user-select: none
margin-left: 5px
margin-right: auto
text: =loop.dimmerItem.label
color: yellow
item: =loop.dimmerItem.name
style:
z-index: 2
margin-left: auto
- component: oh-slider
color: white
releaseOnly: true
label: true
max: '=(loop.dimmerItem.stateDescription && loop.dimmerItem.stateDescription.maximum) ? loop.dimmerItem.stateDescription.maximum : "100"'
style:
position: absolute
--f7-range-bar-active-bg-color: linear-gradient(to right, rgba(50,50,0,.4), rgba(255,255,0,.9))
--f7-range-bar-bg-color: transparent
--f7-range-bar-border-radius: 35px
--f7-range-bar-size: 35px
--f7-range-knob-color: transparent
--f7-range-knob-size: 0px
--f7-range-label-bg-color: transparent
--f7-range-label-border-radius: 5px
--f7-range-label-font-size: 25px
--f7-range-label-font-weight: 600
--f7-range-label-padding: 20px 0px
--f7-range-label-size: 40px
--f7-range-label-text-color: var(--f7-text-color)
filter: 'loop.colorTempItem.metadata.semantics.config.relatesTo == "Property_ColorTemperature" ? true : false'
for: colorTempItem
slots:
default:
- component: f7-row
style:
margin-left: 5px
margin-bottom: 5px
align-items: center
font-size: 1em
text-overflow: ellipsis
white-space: nowrap
slots:
default:
height: 30
icon: f7:dial
style:
z-index: 2
user-select: none
color: '=(loop.colorTempItem.state == "ON") ? "yellow" : var(--f7-text-color)'
- component: Label
style:
z-index: 2
user-select: none
margin-right: auto
text: =loop.colorTempItem.label
color: white
item: =loop.colorTempItem.name
label: true
releaseOnly: true
max: 6500
min: 1700
style:
--f7-range-bar-active-bg-color: linear-gradient(to right, rgba(255, 121, 0,.8), rgba(200, 249, 253,0.8))
--f7-range-label-font-weight: 400
position: absolute
width: 99%
filter: '(loop.colorItem.type=="Color") ? true : false'
for: colorItem
slots:
default:
- component: f7-row
style:
align-items: center
--f7-color-picker-slider-knob-size: 25px
--f7-color-picker-slider-size: 15px
margin-bottom: 5px
slots:
default:
height: 30
icon: f7:slider_horizontal_3
style:
color: '=(loop.colorItem.state == "ON") ? "yellow" : var(--f7-text-color)'
- component: Label
style:
margin-right: auto
text: =loop.colorItem.label
- component: oh-colorpicker
item: =loop.colorItem.name
modules:
- hsb-sliders
- component: f7-tab
class:
- display-flex
style:
margin: 5px
padding: 0px
visible: =(vars.select == 2)
slots:
default:
color: gray
raised: false
strong: true
style:
width: 100%
slots:
default:
action: toggle
actionCommand: ON
actionItem: =props.heatingon_item
active: '=(items[props.heatingon_item].state == "ON") ? true : false'
iconF7: thermometer_sun
large: true
outline: '=(items[props.heatingon_item].state == "ON") ? true : false'
visible: "=props.heatingon_item ? true : false"
action: toggle
actionCommand: ON
actionItem: =props.coolingon_item
active: '=(items[props.coolingon_item].state == "ON") ? true : false'
large: true
outline: '=(items[props.coolingon_item].state == "ON") ? true : false'
visible: "=props.coolingon_item ? true : false"
action: toggle
actionCommand: ON
actionItem: =props.fanon_item
active: '=(items[props.fanon_item].state == "ON") ? true : false'
iconF7: wind
large: true
outline: '=(items[props.fanon_item].state == "ON") ? true : false'
visible: "=props.fanon_item ? true : false"
action: toggle
actionCommand: ON
actionItem: =props.humidifieron_item
active: '=(items[props.humidifieron_item].state == "ON") ? true : false'
iconF7: drop
large: true
outline: '=(items[props.humidifieron_item].state == "ON") ? true : false'
visible: "=props.humidifieron_item ? true : false"
style:
display: flex
width: 100%
align-items: center
justify-items: center
slots:
default:
style:
width: 100%
display: flex
align-items: center
background: linear-gradient(to right bottom, rgb(240, 174, 75), rgb(155, 77, 27))
visible: "=props.temperatureset_item ? true : false"
slots:
default:
- component: Label
style:
text: Задать температуру
- component: oh-stepper
autorepeat: true
fill: true
item: =(props.temperatureset_item)
raised: true
round: true
step: 0.5
style:
--f7-stepper-border-width: 0px
--f7-stepper-fill-button-bg-color: rgba(255, 0, 0, 0.4)
--f7-stepper-height: 40px
--f7-stepper-raised-box-shadow: 2px 3px 10px rgba(0, 0, 0, 0.5), -2px -2px 10px rgba(0, 0, 0, 0.5)
--f7-stepper-value-font-weight: 600
--f7-stepper-value-text-color: var(--f7-text-color)
style:
align-content: center
width: 100%
margin-top: 5px
height: 140px
overflow: hidde
border-style: solid
slots:
default:
color: blue
item: =props.temperatureset_item
releaseOnly: true
label: true
step: 0.5
scale: true
scaleSteps: 6
unit: °C
min: 10
max: 40
style:
--f7-range-scale-step-height: 0px
--f7-range-scale-text-color: var(--f7-text-color)
--f7-range-scale-step-width: 0px
--f7-range-scale-font-size: 18px
--f7-range-scale-font-weight: 600
--f7-range-scale-label-offset: 0px
--f7-range-scale-bg-color: var(--f7-text-color)
--f7-range-bar-active-bg-color: transparent
--f7-range-bar-bg-color: rgba(255, 0, 0, 0.4)
--f7-range-bar-border-radius: 0px
--f7-range-bar-size: 40px
--f7-range-knob-color: rgba(255, 0, 0, 0.4)
--f7-range-label-size: 180px
margin: 100px 0px 0px
width: 100%
visible: "=props.fanspeed_item ? true : false"
slots:
default:
- component: Label
style:
text: Режим вентилятора
fill: true
item: =props.fanspeed_item
max: 4
min: 1
raised: true
round: true
style:
--f7-stepper-fill-button-bg-color: rgba(0, 0, 255, 0.4)
style:
margin: auto
visible: "=props.humidityset_item ? true : false"
slots:
default:
config: {}
slots:
default:
- component: Label
style:
text: Задать влажность
autorepeat: true
autorepeatDynamic: true
fill: true
item: =props.humidityset_item
raised: true
round: true
style:
--f7-stepper-fill-button-bg-color: rgba(0, 255, 255, 0.4)
visible: "=props.humidifierfan_item ? true : false"
slots:
default:
- component: Label
style:
fill: true
item: =props.humidifierfan_item
max: 4
min: 1
raised: true
round: true
style:
- component: f7-tab
class:
- display-flex
style:
margin: 5px
margin-right: 5px
padding: 0px
visible: =(vars.select == 3)
slots:
default:
style:
height: 70px
slots:
default:
large: true
raised: true
style:
box-shadow: 0px 2px 5px
height: 40px
line-height: 1.5
top: 5px
white-space: pre-wrap
word-break: break-word
text: "=(items[props.sourceName].state !== 'UNDEF' ? (items[props.sourceName].state +' '+ items[props.mediaTitle].state) : items[props.mediaTitle].state)"
textColor: var(--f7-text-color)
style:
width: auto
slots:
default:
- component: f7-row
config: {}
slots:
default:
action: command
actionCommand: "=(items[props.power].state === 'OFF') ? 'ON' : 'OFF' "
actionItem: =props.power
iconF7: power
iconSize: 20
style:
background-image: "linear-gradient(360deg, var(--f7-card-bg-color) 10%, #494949 180%)"
border-radius: 12px
box-shadow: 0px 2px 2px
color: "=(items[props.power].state === 'OFF') ? 'var(--f7-text-color)' : 'red' "
width: 25%
action: command
actionCommand: KEY_HOME
actionItem: =props.inputAction
iconF7: house
iconSize: 20
style:
border-radius: 12px
width: 25%
action: command
actionCommand: KEY_MENU
iconF7: menu
iconSize: 20
style:
border-radius: 12px
width: 25%
- component: f7-row
style:
height: 37px
margin-top: 5px
width: 100%
slots:
default:
round: true
strong: true
style:
--f7-segmented-strong-between-buttons: 3px
--f7-segmented-strong-padding: 0px
border-radius: 12px
box-shadow: 1px 0px 8px
width: 100%
slots:
default:
action: command
actionCommand: INCREASE
actionItem: =props.volumeControlItem
iconF7: speaker_3
iconSize: 25
style:
border-right: 1px solid gray
width: 50%
action: command
actionCommand: KEY_CHUP
iconF7: arrow_up
iconSize: 25
style:
border-left: 1px solid gray
width: 50%
- component: f7-row
style:
width: 100%
slots:
default:
round: true
strong: true
style:
border-radius: 12px
box-shadow: 1px 0px 5px
width: 100%
slots:
default:
action: command
actionCommand: DECREASE
bgColor: black
iconF7: speaker_1
iconSize: 25
style:
width: 50%
action: command
actionCommand: KEY_CHDOWN
bgColor: black
iconF7: arrow_down
iconSize: 25
style:
width: 50%
- component: f7-row
style:
margin-top: 10px
slots:
default:
action: command
actionCommand: KEY_RED
bgColor: black
iconF7: circle_fill
iconSize: 20
style:
border-radius: 12px
color: red
width: 20%
action: command
actionCommand: KEY_GREEN
bgColor: black
iconF7: circle_fill
iconSize: 20
style:
border-radius: 12px
color: green
width: 20%
action: command
actionCommand: KEY_YELLOW
bgColor: black
iconF7: circle_fill
iconSize: 20
style:
border-radius: 12px
color: yellow
width: 20%
action: command
actionCommand: KEY_BLUE
bgColor: black
iconF7: circle_fill
iconSize: 20
style:
border-radius: 12px
color: blue
width: 20%
- component: f7-row
style:
margin-top: 10px
slots:
default:
action: command
actionCommand: KEY_REWIND
bgColor: black
iconF7: backward_end
iconSize: 20
style:
border-radius: 12px
width: 20%
action: command
actionCommand: KEY_STOP
bgColor: black
iconF7: stop
iconSize: 20
style:
border-radius: 12px
width: 20%
action: command
actionCommand: KEY_PLAY
bgColor: black
iconF7: playpause
iconSize: 20
style:
border-radius: 12px
width: 20%
action: command
actionCommand: KEY_FF
bgColor: black
iconF7: forward_end
iconSize: 20
style:
border-radius: 12px
width: 20%
style:
height: 220px
width: auto
slots:
default:
action: command
actionCommand: KEY_EXIT
style:
border-radius: 12px
left: 10%
position: absolute
top: 15px
width: 70px
text: EXIT
action: command
style:
border-radius: 12px
position: absolute
right: 10%
top: 15px
width: 70px
text: MENU
action: command
actionCommand: KEY_MUTE
iconF7: speaker_slash
iconSize: 25
style:
border-radius: 12px
color: red
left: 50%
position: absolute
top: 15px
transform: translate(-50%)
action: command
actionCommand: KEY_RETURN
iconF7: arrow_counterclockwise
iconSize: 25
style:
border-bottom: 0px
border-radius: 12px
display: flex
height: 40px
left: 10%
position: absolute
top: 60px
transform: skew(140deg)
width: 15%
z-index: 2
- component: f7-badge
bgColor: gray
style:
border-radius: 100px/100px
height: 160px
left: 50%
position: absolute
top: 60px
width: 160px
z-index: 1
bgColor: black
style:
border-radius: 60px
height: 60px
left: 50%
position: absolute
top: 110px
width: 60px
z-index: 3
- component: oh-link
action: command
actionCommand: KEY_ENTER
style:
font-size: 18px
left: 50%
position: absolute
top: 125px
z-index: 3
text: OK
action: command
actionCommand: KEY_UP
iconF7: arrowtriangle_up
iconSize: 35
style:
left: 50%
position: absolute
top: 67px
z-index: 2
action: command
actionCommand: KEY_LEFT
iconF7: arrowtriangle_left
iconSize: 35
style:
left: 50%
position: absolute
top: 120px
transform: translate(-75px)
z-index: 2
action: command
actionCommand: KEY_RIGHT
iconF7: arrowtriangle_right
iconSize: 35
style:
left: 50%
position: absolute
top: 120px
transform: translate(45px)
z-index: 2
action: command
actionCommand: KEY_DOWN
iconF7: arrowtriangle_down
iconSize: 35
style:
left: 50%
position: absolute
top: 180px
z-index: 2
action: command
actionCommand: left
actionItem: =props.inputaction
iconF7: circle
iconSize: 25
style:
align-items: center
border-bottom: 0px
border-radius: 12px
display: flex
height: 40px
position: absolute
right: 10%
top: 60px
transform: skew(40deg)
width: 15%
z-index: 2
action: command
actionCommand: KEY_GUIDE
iconF7: doc_plaintext
iconSize: 25
style:
align-items: center
border-bottom: 0px
border-radius: 12px
display: flex
height: 40px
left: 10%
position: absolute
top: 180px
width: 15%
z-index: 2
action: command
actionCommand: KEY_INFO
iconF7: info_circle
iconSize: 25
style:
align-items: center
border-bottom: 0px
border-radius: 12px
display: flex
height: 40px
position: absolute
right: 10%
top: 180px
width: 15%
z-index: 2
- component: f7-tab
style:
filter: drop-shadow(0px 1px 1px var(--f7-card-bg-color))
margin: 5px
margin-right: 5px
padding: 0px
visible: =(vars.select == 4)
slots:
default:
- component: oh-list
config: {}
slots:
default:
- component: oh-list-item
accordionItem: false
action: toggle
actionCommand: ON
badge: '=(items[props.lock_item].state == "ON") ? "Закрыты" : "Открыт"'
badgeColor: '=(items[props.lock_item].state == "ON") ? "green" : "red"'
item: =props.lock_item
style:
font-size: large
--f7-list-item-title-font-weight: 620
title: Замок
accordionItem: true
action: analyzer
actionAnalyzerItems: =[props.door_item]
badge: '=(items[props.door_item].state == "ON") ? "Закрыты" : "Открыты"'
badgeColor: '=(items[props.door_item].state == "ON") ? "green" : "red"'
item: =props.door_item
style:
font-size: large
title: Двери
slots:
accordion:
for: item
fragment: true
groupItem: =props.door_item
slots:
default:
action: analyzer
actionAnalyzerCoordSystem: time
actionAnalyzerItems: =[loop.item.name]
badge: '=(items[loop.item.name].state == "ON") ? "Закрыты" : "Открыты"'
badgeColor: '=(items[loop.item.name].state == "ON") ? "green" : "red"'
icon: '=(items[loop.item.name].state == "ON") ? "door-closed" : "door-open"'
item: =loop.item.name
title: =loop.item.label
accordionItem: true
action: analyzer
actionAnalyzerItems: =[props.window_item]
badge: '=(items[props.window_item].state == "ON") ? "Закрыты" : "Открыты"'
badgeColor: '=(items[props.window_item].state == "ON") ? "green" : "red"'
icon: "=(items[props.window_item].state === 'ON') ? 'window-closed' : 'window-open'"
item: =props.window_item
style:
font-size: large
title: Окна
slots:
accordion:
for: item
fragment: true
groupItem: =props.window_item
slots:
default:
action: analyzer
badge: '=(items[loop.item.name].state == "ON") ? "Закрыта" : "Норма"'
badgeColor: '=(items[loop.item.name].state == "ON") ? "gray" : "lightblue"'
icon: '=(items[loop.item.name].state == "ON") ? "window-closed" : "window-open"'
accordionItem: true
action: analyzer
badge: '=(items[props.motion_item].state == "ON") ? "Движение" : "Спокойно"'
badgeColor: '=(items[props.motion_item].state == "ON") ? "red" : "green"'
item: =props.motion_item
style:
font-size: large
title: Движение
slots:
accordion:
for: item
fragment: true
groupItem: =props.motion_item
slots:
default:
action: analyzer
badge: '=(items[loop.item.name].state == "ON") ? "Движение" : "Спокойно"'
badgeColor: '=(items[loop.item.name].state == "ON") ? "red" : "green"'
action: analyzer
actionAnalyzerItems: =[props.leakage_item]
badge: '=(items[props.leakage_item].state == "ON") ? "Утечка" : "Сухо"'
badgeColor: '=(items[props.leakage_item].state == "ON") ? "red" : "green"'
icon: "=(items[props.leakage_item].state === 'ON') ? 'f7:drop_triangle' : 'f7:drop'"
style:
font-size: large
title: Утечка
visible: "=props.leakage_item ? true : false"
action: analyzer
actionAnalyzerItems: =[props.smoke_item]
badge: '=(items[props.smoke_item].state == "ON") ? "Задымление" : "Дыма нет"'
badgeColor: '=(items[props.smoke_item].state == "ON") ? "red" : "green"'
icon: "=(items[props.smoke_item].state === 'ON') ? 'f7:flame_fill' : 'f7:flame'"
item: =props.smoke_item
style:
font-size: large
title: Задымление
visible: "=props.smoke_item ? true : false"
- component: f7-tab
class:
- display-flex
style:
margin: 5px
padding: 0px
visible: =(vars.select == 5)
slots:
default:
style:
text-shadow: none
width: 100%
slots:
default:
- component: oh-chart
height: 50vh
options:
backgroundColor: rgba(0,0,0,0.5)
color:
- red
- "#01ffa6"
- yellow
- "#1689f2"
textStyle:
color: white
slots:
dataZoom:
- component: oh-chart-datazoom
type: inside
grid:
- component: oh-chart-grid
includeLabels: true
left: center
width: 60%
legend:
- component: oh-chart-legend
bottom: 1
textStyle:
type: scroll
series:
- component: oh-time-series
gridIndex: 0
item: =props.temp_item
type: line
xAxisIndex: 0
yAxisIndex: 0
gridIndex: 0
item: =props.humidity_item
type: line
xAxisIndex: 0
yAxisIndex: 1
gridIndex: 0
item: =props.lightlevel_item
type: line
xAxisIndex: 0
yAxisIndex: 2
gridIndex: 0
item: =props.CO_item
type: line
xAxisIndex: 0
yAxisIndex: 3
tooltip:
- component: oh-chart-tooltip
confine: true
smartFormatter: true
xAxis:
- component: oh-time-axis
gridIndex: 0
yAxis:
- component: oh-value-axis
gridIndex: 0
nameLocation: start
position: left
show: "=props.temp_item ? true : false"
gridIndex: 0
nameLocation: start
position: right
show: "=props.humidity_item ? true : false"
gridIndex: 0
nameLocation: start
offset: 20
position: left
show: "=props.lightlevel_item ? true : false"
gridIndex: 0
nameLocation: start
offset: 30
scale: true
show: "=props.CO_item ? true : false"
The part with the thermostat is at line 806. Target temperature item should be passed to widget to show thermostat in editor’s preview.
Cutted part with thermostat only is:
style:
width: 100%
margin-top: 5px
height: 140px
overflow: hidde
border-style: solid
slots:
default:
color: blue
releaseOnly: true
label: true
step: 0.5
scale: true
scaleSteps: 6
unit: °C
min: 10
max: 40
style:
width: 100%
I’m struggling to correctly cut off a part of knob going out of slider’s field (seen on the left on the picture) and to place scale label. Any ideas?
