Hi i am using win10, and Runing OH2.2
i want to move to another machine what is the best way to back up and restore OH
once i will have it runing on the new machine?
i have tried V2P and had no luck
anyone can think of a good idea?
i have tried using some of the posts here but some commands seems not to work for my karaf OH
you may also need to download OH v2.2 the zip version copy it too your new machine unzip and launch OH let it run close it and replace the contents of the zip with your files
acctully it is the same machine that i ported to VM(for backup)
then pysical crashed … wanted to restore with V2P but no luck
so i am taking the OH from the VM and putting it back on the pysical that it came from
after a fresh W10 install,java and all the rest
i know very long way, but i was lucky enough to back it all up!
