Try to format the Temperature in Habpanel to show only one digit (10.3 °C) instead of 2 digits (10.34 °C)
I use the Openweathermap Binding. In the Item OneCallAPIweatherandforcast_Current_Temperatur the Value is shown with 2 digits, like 10.61 °C.
If i create a TestPage and display the Item there, it is displayed as 10.6 °C which is fine.
But i try to use this in habpanel (to show an overview of all relevant things on a wall mounted tablet) the Item is displayed as 10.61 °C
In the Habpanel i have used this code:
{{itemValue("OneCallAPIweatherandforecast_Current_Temperatur')}} to show the Value.
I read a lot of posts the last days, and try a lot of things to format the Value, but was not successful...
Maybe someone could show me how to format the value.
Thank you !
Did you try to add a State Description with %.1f %unit% or %.2f %unit% (one or two decimals).
Never used habpanel but it worked for someone else i know.
I tried to add a pattern at the Item, but this did not change anything.
Is there any other place where i could add the State Description?
Until now i didn’t add any textfile (.map or .item) or something like this.
