I have cobbled together the script below (from other peoples various scripts) and I am in need of some assistance…its become a bit unwieldy…
The principles are:
- When the sensor detects movement, the lights should go on
- Unless it is dark - when it should remain off - I take care of the ‘Is it dark’ in another rule - which works
- After 3 minutes of inactivity the lights should go off
I created a switch ‘Night Mode’ that I have toggled by my phone when it is on charge and after 11pm - using tasker.
I would like to have the lights dim when in Night Mode and then reset to full brightness in the morning - whilst staying off (or briefly coming on to reset).
Can anyone help?
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.openhab.model.script.actions.Timer
var Timer hall_timer = null
var Integer hall_timeout = 3
rule "hall light motion"
Item EventState06 received update "DetectedMovement"
logInfo(“hall”, “Movement Detected”)
if (Is_Dark.state == ON){
if (hall_timer != null)
hall_timer.reschedule(now.plusMinutes(hall_timeout))
logInfo(“hall”,“hall timer rescheduled for " + hall_timeout + " minutes”)
else
if Night_Mode.state == ON {
else
Hall.members.forEach[s | s.sendCommand(ON)]
logInfo(“hall”,“hall timer create with " + hall_timeout + " minutes”)
hall_timer = createTimer(now.plusMinutes(hall_timeout))
if (EventState06 == “DetectedMovement”)
logInfo(“hall”,“hall timer triggered, but rescheduled again for " + hall_timeout + " minutes”)
else
Hall.members.forEach[s | s.sendCommand(OFF)]
hall_timer = null
else
logInfo(“hall”,“night mode activated, skipping”)
