In your door.map are you using all uppercase letters for OPEN and CLOSED? I think case matters in this situation.
The shield icons change based on a number so look at the shield icons in the /webapps/images folder, see which ones are the color you want and make your motion.map convert what ever number coming in corresponds to the icon color you want. For example, if a 1 indicates movement and the red shield is shield-2 the map should be 1=2. As with Node01Door, put it in your sitemap as a Text item.
I tried all the ways with capital letters and small letter, numbers but it doesnât want to go if i define the item âContactâ the result is unavailable.
If i leave âNumberâ instead of âContactâ and in the map i use 1=open 2=close it works but as i said it doesnât move the icon . By the way, the frontdoor icon donât want to appear even i have it in the images folder.
The shield was just as an example that it works with item type âNumberâ and after checking the image folder i saw that the green one is labeled shield-1.png and the red one is shield-0.png so this item work well.
Why i cant see the front door icon even i have it in my image folder. Also the door icon doesnât work too? The icon for the front door is frontdoor-open.png and frontdoor-close.png.
âŠ
Thanks for the answer.
I really donât know whatâs happening with this simple thing (this suppose to be really simple) but for me it doesnât want to work as it is normal to work!
I tried your eg and is not working âŠ
Thereâs something wrong with the door and frontdoor icons, they just donât want to appear in the web! if i change âdoorâ or âfrontdoorâ with âcontactâ the icon appear but is grey so this means is just an icon not a contact item type.
In the door.map i tried again all the version like:
open=OPEN and closed=CLOSED or 0=OPEN and 1=CLOSED or OPEN=OPEN and CLOSED=CLOSED
nothingâŠ
The other eg for the weather is like impossible for me for the next 2 years to make it work if i face so many troubles with this simple thing .
the frond door icon appear and more over it works BUT i dont see the text in the right side of the web with OPEN or CLOSE status.
if i change something in the map like 0=open or 0=Open itâs not going to work anymore.
How do i make the OPEN / CLOSE status to appear on the web?
Thanks again.
Excellent news! Almost there. Hopefully you are learning how all of these OH configurations work and how they work together now. The first project is always the hardest. And since you moved to MQTT you have a good foundation for expanding you HA system with more Arduino based sensors and actuators going forward.
Hopefully you are reading the wiki as well as these postings and the examples to learn what all of these things mean and how they are interacting with each other. If so the Weather binding will be no sweat. The weather binding is MUCH easier to work with so once you get this MQTT stuff working start to play with the Weather binding. After I got my first couple of switches to work in OH I spent a month or so experimenting with the Weather and Astro bindings. These two are great for learning because they donât require a bunch of external stuff to work along with it and they let you start to program some cool capabilities like turning on the lights when the weather says its cloudy or turning on a light 90 minutes before sundown.
I think I know what is going on. We already mapped the 0, and 1 to OPEN / CLOSED in the MQTT binding (stuff in { }) and the resultant value is used for the Contactâs value. Thus, when the UI goes to display it the value is already set to OPEN or CLOSED so the MAP in your label text doesnât work as it only has values for 0 and 1.
You can either eliminate this MAP in the label (e.g. âUsa acces [%s]â) which should put OPEN or CLOSED (note the all caps) on your sitemap. Iâd try this first to make sure this is indeed the problem.
If you would rather it be all lower case or just the first letter capitalized, or have the Romanian? (Google translateâs guess) for open and closed printed, add âOPEN=deschisâ, and âCLOSED=Ăźnchisâ (or whatever you want to convert the OPEN / CLOSED to on your UI) and leave the item definition unchanged from what is currently working with the icons. Note that this sort of mapping may prove useful as you start to experiment with the Weather binding if you want to translate the values from English in your display.
Do not edit or remove the 0=CLOSED and 1=OPEN. You need to add these as new lines.
There is a tiny chance this wonât work as expected. If it doesnât create a new map file with the OPEN= and CLOSED= and use that map in the label text.
Thanks Rich, you were right, all i had to do was to remove the MAP in the label.
You guessed right, Iâm from Romania and because itâs working with OPEN/CLOSE i prefer to leave it like this instead of DESCHIS/INCHIS
However there is something wrong. Iâll try to make a short description: if i leave the configuration like this is working well, i mean i can see in real time when the contact is closed that Openhab changes its status from OPEN to CLOSE but when developing application with multiple items, this contact still works but not in real time. When i close the contact nothing appears on the web, the door is still open. If i move to another page or out of the app and get back in, i see the contact CLOSE but not in real time! Why is that?
I would like to ask you if i need multiple MAPâs like door1.map, door2.mao,âŠfor multiple contacts or i can use this one i have right now?
You right, I am reading on wiki, Iâam testing some of the examples but there are a lot of things i donât understand. You saw the contact e.g. I simply could not make it work from the first shot.
You said you have some switches working on Openhab, may i ask you if you can share your configuration?
For the moment the 4 sensors i have connected on the Arduino work well but you remember on the beginning of this topic I was asking for some OH settings because i had one switch (contact) working following the tutorial form MySensors (different solution) and now because i followed another tutorial form another site everything is different.
My old wish is to have a small home automation system for a few switches which suppose to have to ways communication for lights: physical button and OH button for one light and to see any changes of the status in real time, A few sensors like temp, humidity, electric (SCT-013-000), water, gas using some sensors for the Rasberry and Arduino.
The bad thing is that every time i try to modify or to develop any Arduino sketches i face a lot of troubles, errors that i canât clean and so all the time iâm changing the solution following a different tutorial or topic which suppose to use different sensors or different solution as for example now when i changed the communication from the serial to Mqtt and from MySensors to Home automation for geeks.
Hopefully with this solution iâll be able to add the elements i want in my small home system.
This is a behavior that I and others have seen. I think the UI doesnât poll the server often enough to always see all the changes all the time. The problem seems worse on Android and iOS clients than on the web UI. Iâve not had problems with Contacts before. It is usually with switches. See this thread for more discussion on the problem.
You can use the same MAP for all your doors.
I can but donât know how terribly useful they will be regarding the configuration. As I hope you are realizing, everyone has different requirements and approaches to HA. My approach may not be suitable for what you want to achieve or be compatible with the examples you are finding and copying from online.
I have three z-wave switches and two HTTP binding based switches (which Iâm probably going to move to a MQTT configuration for consistency at some point). Iâm using a z-wave USB dongle as the controller so I have the âzwave:portâ property in openhab.cgf set to â/dev/ttyUSB0â which is where the USB dongle resides. The HTTP switches are calling the REST API of WebIOPi on a Raspberry Pi wired to a couple of relays.
Items:
Group:Switch:OR(OFF,ON) gLights "All Lights" <light>
Group gWeatherLights "Lights controlled by weather conditions and twilight" <light>
Group gOffTimerLights "Off Timer Lights" <light>
Group gSunsetTimerLights "Sunset On Lights" <light>
Switch S_L_Front "Front Room Lamp" <light> (gLights, gOffTimerLights, gWeatherLights) {zwave="3:command=switch_binary"}
Switch S_L_Family "Family Room Lamp" <light> (gLights, gOffTimerLights, gWeatherLights) {zwave="4:command=switch_binary"}
Switch S_L_Porch "Front Porch" <light> (gLights, gOffTimerLights, gSunsetTimerLights) {zwave="6:command=switch_binary"}
Switch S_L_All "All Lights" <light>
Switch T_D_Garage1 "Garage Door 1" <garagedoor>
Switch T_D_Garage2 "Garage Door 2" <garagedoor>
Note: I have two additional zwave switches that get toggled when one of my Raspberry Pi controllers is detected as being offline to too long. Iâve found the Raspberry Pis are not very stable and drop offline far too often. Iâm not going to show these here though as they donât add anything regarding Switches.
Rules:
The Garage Door switches are implemented in rules rather than on the Item definition primarily because I have a bunch of book keeping and such that I want to do in addition to just triggering the garage door. The rules call a lambda (reusable function) that constructs a URL to get and sends a notification if the door is opened and no one is home or if the Network Health binding is saying that the Raspberry Pi is not online.
import org.openhab.core.library.types.*
import org.openahb.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
import org.eclipse.xtext.xbase.lib.*
val Functions$Function1 openGarage = [ String garageNum |
logInfo("Garage Controller", "The garage door " + garageNum + " has been triggered")
var url = "http://192.168.1.201:8000/GPIO/"
switch garageNum {
case "1" : url = url + "17"
case "2" : url = url + "22"
default : url = null
if (url == null) {
sendNotification("rlkoshak@gmail.com", "Received cmd to trigger unknown garage door: " + garageNum)
logError("Garage Controller", "Received cmd to trigger unknown garage door: " + garageNum)
else {
url = url + "/sequence/500,01"
logDebug("Garage Controller", "The URL is " + url)
sendHttpPostRequest(url)
if (gPresent.state != ON) {
sendNotification("rlkoshak@gmail.com", "Garage door " + garageNum + " has been triggered.")
if (gGarageNet.state != ON) {
sendNotification("rlkoshak@gmail.com", "The garage controller may be offline, trigger may have failed: WEBIOPi = " +
N_C_GarageWebIOPi.state + " Raspi = " + N_C_GarageRaspi.state + " Repeater = " + N_C_GarageRepeater.state)
true
rule "Garage Door Opener 1"
Item T_D_Garage1 received command
openGarage.apply("1")
rule "Trigger Garage Door Opener 2"
Item T_D_Garage2 received command
openGarage.apply("2")
The lights rules are quite a bit more complicated. If you put the light Switches on the sitemap as is they will work as is, no need for rules. However my HA automation philosophy is that it should automatically do what it should and if you have to use a user interface it is a HA failure.
The lights have four cases. Some go on when the Weather Binding Condition ID says it is cloudy. Some turn on 90 minutes before sundown (twilight), some that turn on at sundown, and some those that turn off at 11 pm. Most lights are members of multiple of these groups. If during the day a light is manually turned on, the Weather rule is disabled for that light.
import org.openhab.core.types.*
import org.openhab.core.library.items.*
import java.util.Map
import java.util.Set
// Global Variables
val String TIMER = "TIMER"
val String WEATHER = "WEATHER"
val String MANUAL = "MANUAL"
val Map<SwitchItem, Boolean> overridden = newHashMap
var boolean day = true
var String whoCalled = ""
// Yahoo cloudy weather condition IDs
val Set<String> cloudyIds = newImmutableSet("0", "1", "2", "3", "4", "5", "6", "7", "8",
"9", "10", "11", "12", "13", "14", "15", "16", "17",
"18", "19", "20", "26", "28", "35", "41", "43", "45",
"46", "30", "38")
val Functions$Function4 applySwitch = [ State state,
boolean override,
String whoCalled,
SwitchItem light |
if(state != light.state) {
if(!override) {
logInfo("Lights", whoCalled + " turning " + light.name + " " + state.toString)
sendCommand(light, state.toString)
else {
logInfo("Lights", whoCalled + " " + light.name + " is overridden")
rule "Lights System Startup"
System started
whoCalled = MANUAL
gLights?.members.forEach[light | overridden.put(light as SwitchItem, false) ]
// TODO Figure out how to deal with it being called three times for each update
rule "Any light in gLight triggered"
Item gLights received update
Thread::sleep(250) // give lastUpdate time to be populated
val mostRecent = gLights?.members.sortBy[lastUpdate].last as SwitchItem
logDebug("Lights", "Most recent is " + mostRecent.name)
if(whoCalled == MANUAL) {
logInfo("Lights", "Overriding " + mostRecent.name)
overridden.put(mostRecent, true)
// The Any gLight triggered will be called for each of items in gLights, causing
// them to become overridden
rule "All Lights"
Item S_L_All received command
gLights?.members.forEach(light | sendCommand(light, S_L_All.state.toString))
rule "Lights Twilight"
Item Twilight_Event received update
logInfo("Lights", "Timer turning Twlight lights.")
whoCalled = TIMER
day = false // deactivate the weather rule
gWeatherLights?.members.forEach[light |
applySwitch.apply(ON, false, TIMER, light)
rule "Lights Sunset"
Item Sunset_Event received update
logInfo("Lights", "Timer turning on Sunset lights.")
whoCalled = TIMER
gSunsetTimerLights?.members.forEach[light |
rule "Lights Bedtime"
Time cron "0 0 23 * * ? *"
logInfo("Lights", "Timer turning off bedtime lights.")
whoCalled = TIMER
gOffTimerLights?.members.forEach[light |
applySwitch.apply(OFF, false, TIMER, light)
rule "Lights Sunrise"
Item Sunrise_Event received command ON
logInfo("Lights", "Good morning, activating Weather Lights rule")
day = true
whoCalled = MANUAL
logDebug("Lights", "Populating overridden map with " + light.name)
rule "Weather Lights On"
// Time cron "0 */10 * * * ?" or
Item Condition_Id changed
if(day) {
logDebug("Lights", "Checking the weather conditions")
var State state = OFF
if(cloudyIds.contains(Condition_Id.state)) state = ON
whoCalled = WEATHER
val i = gWeatherLights?.members.iterator
while(i.hasNext) {
val light = i.next
logInfo("Lights", "Processing " + light.name)
if(overridden.get(light) == null) overridden.put(light as SwitchItem, false)
applySwitch.apply(state, overridden.get(light).booleanValue, WEATHER, light)
Thread::sleep(500)
whoCalled = MANUAL
Sitemap:
The sitemap configures the garage door switches as mere buttons and I have it configured where it uses a different icon based on whether the door sensor says it is open or closed.
The lights have two switches on the sitemap. One switch that will toggle all of the lights. The other is a Group that when clicked will show all the lights which can be switched individually.
Frame label="Controls"{
Switch item=T_D_Garage1 label="Garage Door 1" icon="garagedoor-closed" mappings=[ON=Open] visibility=[N_D_GarageDoor1!="OPEN"]
Switch item=T_D_Garage1 label="Garage Door 1" icon="garagedoor-open" mappings=[ON=Close] visibility=[N_D_GarageDoor1=="OPEN"]
Switch item=T_D_Garage2 label="Garage Door 2" icon="garagedoor-closed" mappings=[ON=Open] visibility=[N_D_GarageDoor2!="OPEN"]
Switch item=T_D_Garage2 label="Garage Door 2" icon="garagedoor-open" mappings=[ON=Close] visibility=[N_D_GarageDoor2=="OPEN"]
Text item=gGarageNet label="Garage Door Control Is Not Online!" visibility=[gGarageNet!="ON"]
Switch item-S_C_Garage label="Reset Garage Controller, turn off then on" visibility=[gGarageNet!="ON"]
Switch item=S_L_All icon="light"
Group item=gLights label="Individual Lights" icon="light"
In openHAB a Contact is not the same thing as a Switch. A Contact is a sensor that shows whether something is OPEN or CLOSED. A Switch is an Item that can be turned ON or OFF. How it is shown in the user interface and how you use them in your rules and how you set them up as an Item are all different. You need to know and understand these sorts of things to be successful with openHAB which is why I am constantly pointing you to the wiki.
I highly recommend using a commercial solution for this. Z-wave, Insteon, and Hue all seem to be pretty popular among posters here on the forum. If you want to roll your own, you will need to code something on whatever is controlling your relay that can received commands from openHAB (e.g. MQTT message, HTTP REST API call which is what I have right now in the garage), etc.
Again, this is why I keep suggesting you spend the time to learn these technologies. You will spend far less time in the long run and experience far less frustration if you get to a point where you can understand what is happening, what the errors are and what they mean, and how to fix them. Otherwise you will be running from one example to the next and failing to get it to work or breaking what already works. I know you have spent a lot of time on this and are learning a lot but still a lot of your questions show a lack of understanding of some very basic things you should know to be successful.
This is what I was afraid. Honestly this is too much for my understanding at this moment.
I really donât want to use now other technologies like zwave or philips, I just want to use my present installation but with small modification like installing some relays in my electrical panel and from there some wires through my existing cable trays or directly in the false ceiling. Moreover I have already some spare cables installed and I want to use them.
You were right, I canât use your eg right now but maybe if you move from http to mqtt I may be using some of your configuration.
About the door.Map I added another 2 window contacts but they are not coded in the Arduino yet and when I open the existing one all 3 contacts display open or close, is this normal?
About controlling some of the switch I have to find answers from other sources but I would like to ask another thing:
I have an electrical strike and I want to make some kind of OH button that will display in text and color like in blue when is on or close and with red color when is off or open. The button should look like the the one for the dinner, evening or movie scene, only that this will indicate my electrical strike state and will control it.
One more question:
I made 1 switch and one dimmer for the same switch and normally when you dimm the light from off to on letâs say 50% the switch should indicate that itâs on but in my case the switch doesnât do anything even if I dimm the light to 100%.
All eg are copied from github demo.
Many thanks for your time.
I will suggest that reviewing and understanding my example and how you would convert it to MQTT would be a first step towards growing your understanding of openHAB. I really believe that without that basic understanding proceeding to grow your system will be an exercise in frustration.
This is not normal. Are all of your Contacts subscribing to the same MQTT topic?
Please review the Sitemaps wiki page and the demo.sitemap in the demo.sitemap. Pay special attention to the mappings (controls the text of the button), and valuecolor attributes on the sitemap.
I donât have enough information to help with this one. Remember, you need to post your items, rules, and sitemap or else we are just guessing what could be wrong or how to help.
Man is damn hard to try to learn a new language without a teacher or any other help. Could you imagine how hard is to learn Chinese language and pronunciation without hearing it once?
This is Openhab for me now
After long searches and readings on the git page i got this item:
Switch FrontDoor "Front door yale state" <key>
and this sitemap:
Switch item=FrontDoor mappings=[OFF="LOCKED"]
Now as i said i want when pressing the button to change from LOCKED (blue) to UNLOCKED (red), donât know how!
If i make the mappings like this:
i get two buttons and i donât want that.
There will be another ask: how to make it stay red / unlocked until the strike will lock by its self . The lock is NC so i would like to keep the red button until the 5 seconds pass, the strike will be locked and the button become blue / locked.
How difficult can be to make this happen?
PS: i managed to add some new contacts on my system and i would like to make a group called contacts who will display on the main page how many of them are open. I know, i have to read on wiki git but can you please tell me where? i couldnât find this yet.
i think you have to deal with .map files, have you already try/read about
them?
there you set the translation âbetween words and numbersâ, depending on
what the Contact/Sensor is sendingâŠ
for the Group i remember that in the Demo configuration there was something
about Windows or Doors open/closed, so maybe it helps you out
â Edit: i see you already deal with map files, sorry for that suggestion.
It would be nice if you post your config files to better understand/see where are the problems and learn from them too.
Have a nice day
I donât know if there is a straight forward way to do this. What Iâve done in my sitemap is use the âvisibilityâ attribute on the sitemap to hide one version and show the other and then swap between them when the state changes. I should note that this doesnât work super well on the mobile clients which donât seem to update very frequently.
Iâm not sure I completely understand what you are asking. I think what you are asking is to wait five seconds before updating the sitemap when the state changes from OFF to ON.
The only way to do that is to create a proxy item for FrontDoor and then use a rule to keep it in sync with the actual sensor/switch and use a timer.
Items:
Switch FrontDoorProxy "Front door yale state" <key>
Rules:
rule "Update FrontDoorProxy"
Item FrontDoor changed
if(FrontDoor.state == ON) {
createTimer(now.plusSeconds(5), [| FrontDoorProxy.sendCommand(ON)])
} else {
FrontDoorProxy.sendCommand(OFF)
You need to create a Number item and create a rule to update that item whenever the group gets updated.
Items:
Group Contacts
Contact ... (Contacts) ...
Number numberContactsOpen
Rules:
rule "Update numberContactsOpen"
Item Contacts received update
val numOpened = Contacts.members.filter(contact | contact.state == OPEN).size
numberContactsOpen.postUpdate(numOpened)
Sitemap:
Text item=numberContactsOpen
A lot of the things you are asking are starting to get more advanced. This is good. It means you are growing in your knowledge of openHAB. Keep it up.
Group item=Contacts label="Status Ferestre" icon="contact"
What i want to do is to see on the right part of this tab, the number of the opened contacts.
I followed your example and its not working. Could you please be more specific?
About the button blue /red here i tried your eg too and its not changing the color on the web. What i wanted to say was that ill use an Arduino to trigger an relay and than the yale through a 12 volts power source. The red color / unlocked should stay red until the yale / relay will not receive power from the Arduino digital pin so in case iâll not manage to do this ill choose your eg but it should change its color and text. Right now i couldnât see this action on the eg you gave me. Where iâm Wrong?
PS: Why you have posted the sitemap in two different ways?
Are there errors in the log? I just typed this in so I donât know if there are typos. You have to check the log to see if there are errors complaining about errors parsing the Item files or executing a rule. If there is a problem with the rule you will see something along the lines of âError executing rule âŠâ Things never just not show up without some error being written to the log.
Did you update the names of Items in the rule to correspond to what your actual items are named? Have you installed Designer and are you editing the rules and items there? Designer will tell you if there are errors in a lot of cases before you run.
You have to create another Item to store the count and put that on your Sitemap. If you put the Group on your sitemap there is no way to put the count. If you want the Item that stores the count to act like a Group on the sitemap you have to use the Frames as described in the wiki for Sitemaps.
rule "Update ContactsCount"
ContactsCount.postUpdate(numOpened)
Sitemap:
Text item=ContactsCount {
Frame {
Text item=Node01Door
Text item=Note01Geam1
Text item=Node01Geam2
The site may not update fast enough. If you refresh the page do the changes show up? If not look in the log for errors. If so Iâm afraid the UI isnât going to work the way you want it to. I have a similar problem with some of my sitemap items.
I donât understand the question. You had two different problems which required two different ways to display it in the sitemap. If you are asking why I used Switch for one and Text for the other see the Sitemap wiki, in particular the âElement âSitemapââ section.
Now we are talking
Thanks! it seems that the problem was that instead of group i should make frame as you said and to put the items in the sitemap! now its working and its displaying the no of the open contacts. Iâm still facing the same refresh problem as i said somewhere above, if i open a contact i cant see in the frame the no. changing but if i go inside the frame its refreshing and i can see each contact in real time (1 sec delay). If i go back into the frame, the no. of open contacts is the right one âŠ
I can loose this error by rebooting the Rasberry and restarting everything all over again. Than, after reboot everything seems to work fine and i can see in the frame that the no. is changing depending on the contacts state.
There is still something which is not working well and this is the icon of the contacts in the frame is not active. It doesnât matter if any contacts are open or closed, the icon is grey, its not changing its form. Can i do something to make it show open contact if any of the contacts is open? if all closed the icon should be closed.
About the button, i dont know how to explain but lets say that if the button is pressed this means that for lets say for 5 sec the button should be red and to display in text inside of it unlocked. After these 5 sec the button should come tho its first state this being blue / locked. Right now using the button on the web, and having this items:
Switch FrontDoor "Yala Usa Acces" <key>
Switch FrontDoorProxy "Yala Usa Acces" <key>
with the rule you posted i see on the RPi terminal that the âFrontDoorProxy received command OFFâ, thats all. no color changed or other message on the terminal.
Today i learned a new thing with your help, to create frames as groups and i will definitely apply this for the switches, thanks man.
Yes, I see this same problem with my sitemap. It is worse on the mobile devices than on the web page but it occurs there too. I have no solution for this problem. This is just the way it is. Iâve not tried your rebooting trick but if that is what it takes to make it work Iâll just live with it as is.
Yes but not easily. You can use the visibility attribute and apply a different icon depending on whether Contacts is ON or OFF but this will have the same refresh problem you identify above. It also makes your sitemap start to get ugly as you have to reproduce a lot of things more than once.
Item:
Group:Switch:OR(OFF,ON) Contacts // This makes your group also behave like a Switch
Sitemap:
Text item=ContactsCount icon="contact-open" visibility=[Contacts.state=="ON"]{
Frame {
Text item=ContactsCount icon="contact-closed" visibility=[Contacts.state=!"ON"]{
Frame {
This is almost certainly the same problem that is keeping the count of your open contacts from updating on the user interface. It is doing the work in the background but the user interface is not updating. There really isnât much I can suggest for this. It is not something that openHAB was apparently designed to handle.
Note your typo: it needs to be frontdoor-closed.png. You were missing the âdâ.
You can also use say <myicon> in items file, then say for a switch (which has states âONâ and OFF"), you would need to place files myicon.png, myicon-on.png and myicon-off.png in the images folder. Also works for Dimmer items (place files XXX-10.png, XXX-20.png etc.) or, like you already found out, for enumeration/integer number items like the shield icon example.
@rlkoshak Rich your second example doesnât do anything. If i replace the first eg with the second one (group item) no open or close icons appear, i cant see in the sitemap the group or the counter. Maybe the items needs to be modified? I tried also to combine the two eg. but still nothing seems to work.
@mstormi Markus i saw the mistake and i replaced the âtâ with âdâ. I have already the contact icons in the image folder and the contact icons in the items too, please see 4 comments above but i didnât understand how exactly to make this to work in the group page (main page) and to have also the counter displaying the right no. of the open contacts.
@mstormihttps://community.openhab.org/users/mstormi Markus i saw
Not replace but add. You wrote âfrontdoor-close.pngâ, but it has to be
âfrontdoor-closed.pngâ.
I use the following in items file (and no overriding definition in
sitemap):
Thereâs files âpresent-open.pngâ and âpresent-closed.pngâ in images folder.
UI shows (on right hand side) the number of âCLOSEDâ items in group
âBewegungsmelderâ. Technically, it does not count the number of âCLOSEDâ
items,
but the âORâ is being computed at runtime and is a simple math operation
using â1â for âCLOSEDâ and â0â for âOPENâ.
UI also shows (on left hand side) the icon. If the number of closed
items (the result of the math operation) is 0, then it shows the
(black&white) âpresent-closed.pngâ icon.
If >1, it shows the (colorful) âpresent-open.pngâ image.
Note: if itâs a contact, you have to use open/closed in items file and
ALSO FOR THE FILENAMES. Whenever itâs a switch, you need to use On/Off,
and whenever itâs a dimmer, I believe
it wonât work because you canât âORâ integer numbers (well,
theoretically it could display something, I didnât try. But it does not
make sense because a single dimmer at say 50% would count as 50 items).
Hm⊠I think weâre talking about two different things
I was talking about Rich eg. here above: âText item=Note01Geam1â instead of âText item=Node01Geam1â
Right now my items in the web start with a open or close window icon depending on the contact state. In the image folder i have these types of contact which looks like a window: contact.png which is grey and means that something is not right (not connected), contact-open.png which looks like an open window, contact-closed.png which looks like an closed window and the last one contact-ajar.png which looks like a window open on the vertical axe.
The icon in the group (main page) should be the contact-open.png if one of the contacts is open and contact-closed.png if all the contacts are closed. On the right side of the hand (screen) or group tab i should see how many of the contacts are open depending on their real state and when pressing on the group tab (going inside the group) to see all the items open or closed.
My front door icon at this moment display the right position of the contact so it works! why are you saying about this âfrontdoor-close.pngâ? i donât understand.
You say that for the contacts state instead of this:
