Hi i need to create 2 string item
first on how told me witch day of the week we are ( in french if possible )
Second the date like 20.12.2016 or something like that
.items
DateTime Today
.rules
// import org.openhab.core.library.types.DateTimeType
// uncomment above on openHAB 1.x
rule SetDay
System started or
Time is midnight
Today.postUpdate(new DateTimeType())
.sitemap
sitemap default label="Home Automation"
Frame label="aujourd'hui" {
Text item=Today label="Aujourd'hui nous sommes [%1$tA]"
Text item=Today label="la date est [%1$d.%1$tm.%1$tY]"
Wow nice ! Thanks for the reply !
I guest i can do : DateTime Tomorrow ?
but if i want the day after tomorrow or the day after that is there a trick ?
Sure (but not tested!)
DateTime Today
DateTime Tomorrow
DateTime DayAfterTomorrow
import java.util.Calendar
rule SetDay
System started or
Time is midnight
val Calendar cal = Calendar::getInstance()
Today.postUpdate(new DateTimeType(cal))
cal.add(Calendar::DAY_OF_YEAR, 1)
Tomorrow.postUpdate(new DateTimeType(cal))
DayAfterTomorrow.postUpdate(new DateTimeType(cal))
it’s working well thanks !
Now my issue is i want use that in other thing (not sitemap (habpanel)) so I would need that the item is really like “Lundi” without string transform … can i make a rule for that ? like tomorrow = tomorrow [%1$tA]
Items can have default labels like
DateTime Today "aujourd'hui [%1$tA]"
DateTime Tomorrow "demain [%1$tA]"
DateTime DayAfterTomorrow "après-demain [%1$tA]"
But I don’t know how HABPanel formats items otherwise. You could add String items and use String::format using the same formatting strings, but ideally that’s not necessary.
yeah … thanks but I made some test and search for info and I rely need a rule that say Today = Today [%1$tA]
so the real value of Today will be “Jeudi” not “2016-12-22T22:20:00.140-0500”
because like i said i’m not gonna use it in sitemap so it need to be already formatted and maybe latter i’m gonna make some rule that like like if Today == Friday send ON command to PARRTTTYY ! ( it’s just an exemple )
OK, how about this (also untested)…
String Today "aujourd'hui [%s]"
String Tomorrow "demain [%s]"
String DayAfterTomorrow "après-demain [%s]"
// import org.openhab.core.library.types.StringType
import java.text.SimpleDateFormat
rule SetDay
System started or
Time is midnight
val SimpleDataFormat day = new SimpleDateFormat("EEEE");
Today.postUpdate(new StringType(day.format(cal.time)))
Tomorrow.postUpdate(new StringType(day.format(cal.time)))
DayAfterTomorrow.postUpdate(new StringType(day.format(cal.time)))
So i change the code reboot Openhab and …
item state is null (from the rest api OH 2.0 )
"link": "http://localhost:8080/rest/items/Tomorrow",
"state": "NULL",
"stateDescription": {
I’ve edited the example above to post a StringType
and not a string. Also check your log to see if there is anything useful there. You can log:tail
at the openhab>
prompt and press Control-C when you want the prompt back.
Still “NULL”
BUT this is what i found in the log :
[ERROR] [.script.engine.ScriptExecutionThread] - Rule ‘SetDay’: An error occured during the script execution: The name ‘.format()’ cannot be resolved to an item or type.
Typo!
Here is a fresh copy tested on OH 1.8.3 and 2.0 Build 644. Change your when/then
block to trigger when you want instead of every five seconds.
import java.text.DateFormat
import java.util.Date
rule SetDay
System Started or
Time cron "0/5 * * * * ?"
var Calendar cal = Calendar::instance
var DateFormat fmt = new SimpleDateFormat("EEEE")
var String todayString = fmt.format(cal.time)
Today.postUpdate(todayString)
logInfo("SetDay","Today is " + todayString)
var String tomorrowString = fmt.format(cal.time)
Tomorrow.postUpdate(tomorrowString)
logInfo("SetDay","Tomorrow is " + tomorrowString)
var String dayAfterString = fmt.format(cal.time)
DayAfterTomorrow.postUpdate(dayAfterString)
logInfo("SetDay","Day After is " + dayAfterString)
Wow thanks !
Little question : why not leave midnight refresh?
My time is not getting update in real time, my site map is as follows
sitemap jackshome label="Jacks-Smarthome"
Frame label="Today"
Text item=Today label="Today [%1$tA]"
Text item=Today label="The Date is [ %1$tA, %1$td/%1$tm/%1$tY %1$tH:%1$tM ]"
Frame label="My South West Room"
Switch item=LEDTB
Switch item=PSRBSTR
Switch item=BDLT
Switch item=FAN
rule SetDay
System started or
Time is midnight
