@tmrobert8
The light switches are defined in OH and exposed to the NEEO brain through the transport.
Here is the log for trying to add a new device. I did remove most of the response of the query as it was over the 32000 character limit on this forum. Could that be an issue? I switched off the firewall. It does not make a difference. I query on ‘Openhab’:
2018-01-25 15:32:13.071 [DEBUG] [ternal.servletservices.SearchService] - Search 'Openha', response: [{"item":{"apiversion":"1.0","adapterName":"nikohomecontrol:onOff:440e003a24e6:7","type":"LIGHT","manufacturer":"openHAB","name":"Inkom","tokens":"","setup":{},"deviceCapabilities":[],"device":{"name":"Inkom","tokens":[]},"capabilities":[{"name":"Licht_Inkom","label":"Inkom","type":"switch","path":"%2Fdevice%2Fnikohomecontrol%3AonOff%3A440e003a24e6%3A7%2FLicht_Inkom%2F1%2Fswitch%2Factor","sensor":"Licht_Inkom"},{"name":"Licht_Inkom","label":"Inkom","type":"sensor","path":"%2Fdevice%2Fnikohomecontrol%3AonOff%3A440e003a24e6%3A7%2FLicht_Inkom%2F1%2Fswitch%2Fsensor","sensor":{"type":"binary"}}],"id":0},"score":2,"maxScore":-1},{"item":{"apiversion":"1.0","adapterName":"nikohomecontrol:onOff:440e003a24e6:6","type":"LIGHT","manufacturer":"openHAB","name":"Trap","tokens":"","setup":{},"deviceCapabilities":[],"device":{"name":"Trap","tokens":[]},"capabilities":[{"name":"Licht_Trap","label":"Trap","type":"switch","path":"%2Fdevice%2Fnikohomecontrol%3AonOff%3A440e003a24e6%3A6%2FLicht_Trap%2F1%2Fswitch%2Factor","sensor":"Licht_Trap"},{"name":"Licht_Trap","label":"Trap","type":"sensor","path":"%2Fdevice%2Fnikohomecontrol%3AonOff%3A440e003a24e6%3A6%2FLicht_Trap%2F1%2Fswitch%2Fsensor","sensor":{"type":"binary"}}],"id":1},"score":2,"maxScore":-1}, ... ,{"item":{"apiversion":"1.0","adapterName":"neeo:device-6360880053269561344:d487672e:room:device","type":"LIGHT","manufacturer":"Wenzhou TKB Control System","name":"Boilerpomp (NEEO d487672e)","tokens":"","setup":{},"deviceCapabilities":[],"device":{"name":"Boilerpomp (NEEO d487672e)","tokens":[]},"capabilities":[{"name":"Boilerpomp Aan","label":"Boilerpomp Aan","type":"button","path":"%2Fdevice%2Fneeo%3Adevice-6360880053269561344%3Ad487672e%3Aroom%3Adevice%2FBoilerpompNEEOD487672e_Macros_TurnOn%2F1%2Fbutton%2Fon"},{"name":"Boilerpomp Uit","label":"Boilerpomp Uit","type":"button","path":"%2Fdevice%2Fneeo%3Adevice-6360880053269561344%3Ad487672e%3Aroom%3Adevice%2FBoilerpompNEEOD487672e_Macros_TurnOff%2F1%2Fbutton%2Fon"}],"id":51},"score":2,"maxScore":-1}]
