If you can also remove the firmware limits, but instead treat 108D as a separate device, then I will be able to test the snapshot binding as well without disabling my old 1083 devices.
If I disable PIR on the 108D then it will simply not detect any motion at all (also the LED won’t flash when I trigger it), which is to be expected, I would say?
If I enable PIR then the LED will flash when triggered, but nothing shows up in the ZWave debug logs. It is happily sending temperature reports, though.
I tried setting the lifeline and that indeed triggered the device once. I had to “Enable PIR” though. However, it doesn’t reset itself to “OK” state after 120 seconds.
I couldn’t reset the switch state manually either:
2018-12-22 19:43:25.074 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 25: Command received zwave:device:9c1948c3:node25:alarm_motion --> OFF [OnOffType]
2018-12-22 19:43:25.077 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 25: No event found with name 'eventOFF'
2018-12-22 19:43:25.079 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 25: No messages returned from converter
@chris I Updated the 401 device and 973
at 973 I did a mistake and added (before) an endpoint. I do not know how to delete it can you help me with this?
I removed version limits from both devices. and removed the 0003:108D from the Old device.
Yes, let’s do that, but please make a note in the comments, and link to this thread so when/if someone complains that we’ve broken their device, we can try and work out what to do next
I just deployed a new build of the zwave binding, and I can confirm that the new motion sensor is now being picked up correctly! I’ve been able to disable the flashing LED and it’s now triggering correct alarms. I also didn’t need to manually set the assocation group.
@billias and others, I have made a post about problems with the NEO Coolcam PIR PD01. I read that the problems are over? Are the Luminance sensor values and the On/Off duration working fine? See the post " Neo Coolcam Motion Sensor PD01 problems"
