- Platform information:
RPI3
openHAB version: 2 - Issue of the topic: sensor is not generating motion detections when it should be. Sensor shows up in logfile and is online, however no motion signals generated or show up in logfile. What could be wrong?
- Please post configurations (if applicable):
- Items configuration related to the issue
- If logs where generated please post these here using code fences:
Which version are you using?
I am using Openhab 2.4.0 release build
PIR motion sensor is configured as a switch in OpenHab. I read in another trace that it should be as a contact. Does not help. Node appears in log, updates also appear, however activitation or motions do not. A rule using the sensor’s motion item/channel as trigger does not work either.
What could be wrong here? Sensor could be bust … it does not generate a blink when motion is made in range of sensor either.
Please provide the debug log showing what is received. I would also recommend changing the 2.5 version of the binding which should ensure that the association can not be removed.
OK - let me work with that - thanks.
chris, you mentioned 2.5 version of zwave binding - where can i get this and how do i get to install it in Openhab 2.4?
Managed to 2.5 version of zwave binding, however it does not appear in Openhab as yet.
Logfile produces following errors:
2019-02-11 07:58:52.420 [ERROR] [org.openhab.binding.zwave ] - FrameworkEvent ERROR - org.openhab.binding.zwave
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.zwave [303]
2019-02-11 08:00:04.507 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode004MotionSensorPIRMotionSensor_BatteryLevel-zwave:device:918814ff:node4:battery-level' has been added.
2019-02-11 08:00:04.515 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode004MotionSensorPIRMotionSensor_AlarmMotion-zwave:device:918814ff:node4:alarm_motion' has been added.
2019-02-11 08:00:04.524 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode004MotionSensorPIRMotionSensor_SensorTemperature-zwave:device:918814ff:node4:sensor_temperature' has been added.
2019-02-11 08:00:04.530 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode004MotionSensorPIRMotionSensor_SensorLuminance-zwave:device:918814ff:node4:sensor_luminance' has been added.
2019-02-11 08:00:04.564 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_918814ff_serial_nak-zwave:serial_zstick:918814ff:serial_nak' has been added.
2019-02-11 08:00:04.572 [.ItemChannelLinkAddedEvent] - Link 'Fietshok_Motion_Sensor-zwave:device:918814ff:node4:alarm_motion' has been added.
2019-02-11 08:00:04.575 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_918814ff_node6_alarm_power-zwave:device:918814ff:node6:alarm_power' has been added.
2019-02-11 08:00:04.583 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_918814ff_node6_meter_kwh-zwave:device:918814ff:node6:meter_kwh' has been added.
2019-02-11 08:00:04.588 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_918814ff_serial_cse-zwave:serial_zstick:918814ff:serial_cse' has been added.
2019-02-11 08:00:04.590 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_918814ff_node6_switch_binary-zwave:device:918814ff:node6:switch_binary' has been added.
2019-02-11 08:00:04.592 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_918814ff_node6_meter_voltage-zwave:device:918814ff:node6:meter_voltage' has been added.
2019-02-11 08:00:04.594 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_918814ff_serial_ack-zwave:serial_zstick:918814ff:serial_ack' has been added.
2019-02-11 08:00:04.596 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_918814ff_node6_meter_current-zwave:device:918814ff:node6:meter_current' has been added.
2019-02-11 08:00:04.598 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_918814ff_node4_battery_level-zwave:device:918814ff:node4:battery-level' has been added.
2019-02-11 08:00:04.600 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_918814ff_serial_can-zwave:serial_zstick:918814ff:serial_can' has been added.
2019-02-11 08:00:04.602 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_918814ff_serial_sof-zwave:serial_zstick:918814ff:serial_sof' has been added.
2019-02-11 08:00:04.610 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_918814ff_node4_sensor_luminance-zwave:device:918814ff:node4:sensor_luminance' has been added.
2019-02-11 08:00:04.614 [.ItemChannelLinkAddedEvent] - Link 'zwave_serial_zstick_918814ff_serial_oof-zwave:serial_zstick:918814ff:serial_oof' has been added.
2019-02-11 08:00:04.617 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_918814ff_node6_meter_watts-zwave:device:918814ff:node6:meter_watts' has been added.
2019-02-11 08:00:04.620 [.ItemChannelLinkAddedEvent] - Link 'Test_switch-zwave:device:918814ff:node6:switch_binary' has been added.
2019-02-11 08:00:04.625 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_918814ff_node4_alarm_motion-zwave:device:918814ff:node4:alarm_motion' has been added.
2019-02-11 08:00:04.626 [.ItemChannelLinkAddedEvent] - Link 'zwave_device_918814ff_node4_sensor_temperature-zwave:device:918814ff:node4:sensor_temperature' has been added.
2019-02-11 08:00:45.004 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar
@chris - any clue what I did wrong - managed to install zwave binding 2.5 - however it does not appear in Openhab. See also logfile above.
The error means that the binding is not installed - or at least not running. So, either the binding bundle, or one of its dependencies are unresolved. It could be that the serial bundle is not installed?
Yes, binding shows in Karaf as installed, not active. What is a serial bundle, where can I get it and where do I install it? Together with 2.5 jar in \openHAB-share\openhab2-addons\ ?
Chris,
Found the feature:install instruction on the community and ran it in Karaf. This returned the following error:
Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse.
Any clue?
Pieter Tjebbes
Restarted Openhab and it looks like 2.5 zwave binding is active now - at least a new version of binding is active (where can i find version number in paper ui?) and according to Karaf version 2.5 is now active!
I’m not sure if it’s listed in the UI if you install manually - the best place is to either confirm using Karaf, or, the binding logs the version when it starts into the openhab.log file.
Chris,
The PIR motion sensor seems to show up, however I can not see in logfile which is which.
I have created a rule using the motion item related to the sensor, using the Paper UI which is supposed to turn on a wall switch. Rule stays in idle mode all the time however. Hitting execute rule button in Paper UI does not help. What could be wrong? Lot of suggestion on community to use text editor - however not too familiar with text editor
Pieter
@chris - managed to setup PIR sensor, it looks like it is showing up in logfile, but rule using the motion sensor remains idle in openhab ui?
Can you provide a log which shows the reception of the PIR motion notification?
Chris,
tried to activate PIR motion sensor and generate notification but nothing appears in logs since today’s last entry for zwave devices see below
2019-02-15 13:29:39.510 [vent.ItemStateChangedEvent] - zwave_serial_zstick_f9036393_serial_sof changed from 528 to 529
2019-02-15 13:29:39.511 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 04 08 06 31 05 03 0A 00 AD D4 00 BB
2019-02-15 13:29:39.523 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=8, callback=4, payload=04 08 06 31 05 03 0A 00 AD D4 00
2019-02-15 13:29:39.528 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=8, callback=4, payload=04 08 06 31 05 03 0A 00 AD D4 00
2019-02-15 13:29:39.532 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-15 13:29:39.534 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Application Command Request (ALIVE:REQUEST_NIF)
2019-02-15 13:29:39.537 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
2019-02-15 13:29:39.540 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 8: SECURITY not supported
2019-02-15 13:29:39.542 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 8: Received COMMAND_CLASS_SENSOR_MULTILEVEL V0 SENSOR_MULTILEVEL_REPORT
2019-02-15 13:29:39.545 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 8: Sensor Type = Luminance(3), Scale = 1
2019-02-15 13:29:39.548 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 8: Sensor Value = 173
2019-02-15 13:29:39.550 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Commands processed 1.
2019-02-15 13:29:39.553 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 8: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2632be.
2019-02-15 13:29:39.556 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-15 13:29:39.558 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-15 13:29:39.561 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-15 13:29:39.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
I will check again later - noticed that there might be some time lag in the log files.
Can you check that just above this log there is not a message being sent to the device? ie I want to check that this message was sent unsolicited from the device, and not polled.
If it was sent unsolicited, then this means that the lifeline is configured correctly, and this also should mean that the device should report motion…
I would then suggest to check the configuration - I see there are some parameters that can influence the PIR - parameters 1 and 4 being the main ones I would look at (sensitivity and PIR enable).
