ali3n8
(Terry)
November 7, 2018, 7:33pm
1
Hello I am having issues with the Nest 2.30 binding. I am able to add my account and I can see my thermostat. I can see all the data it presents in my UI. I am having an issue when it comes to setting the temperature through the basicui. Setting the temperature via the PaperUi works just fine.
Here is the item:
Number:Temperature Therm_Setpoint { channel="nest:thermostat:XXXXXXX:XXXXXXXXXXXXXXXXX:set_point" }
Key info removed for privacy
Here is how I have it set in my sitemap:
Setpoint item=Therm_Setpoint label="Thermostat"
I am a bit stumped on this and not sure what my next steps should be.
vzorglub
(Vincent Regaud)
November 7, 2018, 11:18pm
2
What’s not working? and what do you see in the logs when you change the setpoint on the UI?
ali3n8
(Terry)
November 7, 2018, 11:56pm
3
I see this in the event log:
2018-11-07 18:49:12.051 [ome.event.ItemCommandEvent] - Item ‘Therm_Setpoint’ received command 73
2018-11-07 18:49:12.073 [vent.ItemStateChangedEvent] - Therm_Setpoint changed from 72.0 °F to 73.0 °F
ali3n8
(Terry)
November 8, 2018, 12:00am
4
Ok so further trouble shooting it seems isolated to changing the temperature via the openhab Android app. Paperui and basicui work.
ali3n8
(Terry)
November 8, 2018, 12:04am
5
2018-11-07 19:02:36.337 [WARN ] [nding.nest.handler.NestBridgeHandler] - Nest API error: blocked
