Has anybody been able to successfully get the Nest binding working on OH2?
I’ve got the client id / secret / auth code configured in nest.cfg. I’ve got items configured in a .items file. It doesn’t seem like the binding is even attempting to speak to the Nest API.
And yes, Nest displays my thermostat as “LivingRoom”. No space and nothing in ( ).
With TRACE logging turned on… this is all I get…
10:08:22.459 [DEBUG] [org.openhab.binding.nest ] - BundleEvent STARTING - org.openhab.binding.nest
10:08:22.460 [DEBUG] [.binding.nest.internal.NestActivator] - Nest binding has been started. Version 1.9.0.b3
10:08:22.475 [DEBUG] [org.openhab.binding.nest ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.nest.NestBindingProvider}={component.name=org.openhab.binding.nest.genericbindingprovider, component.id=175, service.id=308, service.bundleid=203, service.scope=bundle} - org.openhab.binding.nest
10:08:22.478 [DEBUG] [org.openhab.binding.nest ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.nest, component.name=org.openhab.binding.nest.binding, component.id=174, service.id=310, service.bundleid=203, service.scope=bundle} - org.openhab.binding.nest
10:08:22.488 [DEBUG] [org.openhab.binding.nest ] - BundleEvent STARTED - org.openhab.binding.nest
10:08:22.516 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
10:08:22.524 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
10:08:22.601 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'claude.sitemap'
10:08:22.839 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'nest.items'
10:08:22.863 [TRACE] [.internal.NestGenericBindingProvider] - validateItemType called with bindingConfig=<[last_connection]
10:08:22.865 [TRACE] [.internal.NestGenericBindingProvider] - validateItemType called with property=last_connection
10:08:22.866 [DEBUG] [.internal.NestGenericBindingProvider] - Processing binding configuration: '<[last_connection]'
10:08:22.868 [TRACE] [.internal.NestGenericBindingProvider] - validateItemType called with bindingConfig==[structures(Claude).name]
10:08:22.870 [TRACE] [.internal.NestGenericBindingProvider] - validateItemType called with property=structures(Claude).name
10:08:22.870 [DEBUG] [.internal.NestGenericBindingProvider] - Processing binding configuration: '=[structures(Claude).name]'
10:08:22.872 [TRACE] [.internal.NestGenericBindingProvider] - validateItemType called with bindingConfig==[thermostats(LivingRoom).target_temperature_f]
10:08:22.873 [TRACE] [.internal.NestGenericBindingProvider] - validateItemType called with property=thermostats(LivingRoom).target_temperature_f
10:08:22.875 [DEBUG] [.internal.NestGenericBindingProvider] - Processing binding configuration: '=[thermostats(LivingRoom).target_temperature_f]'
