Not sure exactly what has happened, I could swear I had this working recently… Anyways, when I press the temperature increase or decrease button for my Nest it appears that OH is sending the existing temp value to the Nest API (and not an increase or decrease of 1 degree). Here is a snip from the Nest log while the current temp was set for 68 degrees, and I I tried to increase to 69.
2015-11-29 11:38:33.928 DEBUG o.o.b.n.internal.NestBinding[:322]- About to set property ‘thermostats(Living Room).target_temperature_f’ to ‘68.0’
2015-11-29 11:38:33.930 TRACE o.o.b.n.internal.NestBinding[:327]- Data model for update: DataModel[devices=DataModel.Devices[thermostats={xxxx=Thermostat[device_id=,name=,locale=,software_version=,structure_id=,name=,name_long=,last_connection=,is_online=,can_cool=,can_heat=,is_using_emergency_heat=,has_fan=,fan_timer_active=,fan_timer_timeout=,has_leaf=,temperature_scale=,target_temperature_f=68,target_temperature_c=,target_temperature_high_f=,target_temperature_high_c=,target_temperature_low_f=,target_temperature_low_c=,away_temperature_high_f=,away_temperature_high_c=,away_temperature_low_f=,away_temperature_low_c=,hvac_mode=,ambient_temperature_f=,ambient_temperature_c=,humidity=,hvac_state=]},smoke_co_alarms=],structures=]
2015-11-29 11:38:33.933 TRACE o.o.b.n.i.m.AbstractRequest[:125]- About to execute ‘https://developer-api.nest.com/?auth=xxxx’
2015-11-29 11:38:34.619 TRACE o.o.b.n.i.m.AbstractRequest[:166]- {“devices”:{“thermostats”:{“xxxx”:{“target_temperature_f”:68}}}}
I am still receiving humidity and ambient temperature values back, so I am thinking the connection to Nest is fine. Here is what the corresponding portion of my sitemap looks like (pretty much a straight copy off the Wiki example).
Setpoint item=living_room_target_temperature_f label=“Target Temperature [%.1f °F]” minValue=“45” maxValue=“70” step=“1” visibility=[living_room_hvac_mode==“heat”,living_room_hvac_mode==“cool”]
Setpoint item=living_room_target_temperature_low_f label=“Minimum Temperature [%.1f °F]” minValue=“50” maxValue=“80” step=“1” visibility=[living_room_hvac_mode==“heat-cool”]
Setpoint item=living_room_target_temperature_high_f label=“Maximum Temperature [%.1f °F]” minValue=“50” maxValue=“80” step=“1” visibility=[living_room_hvac_mode==“heat-cool”]
Thank you for reading!
