So Ive installed the nest binding and confgured it, but my Basic UI shows no updates. An help appeciated!
I have nest events in my logifle:
nest_thermostat_xxxxxe9_71_QGTaikHSHWvuumNUaSgTSUGYCNhh3_set_point changed from 20.0 to 18.5
nest_thermostat_xxxxxe9_71_QGTaikHSHWvuumNUaSgTSUGYCNhh3_mode changed from ECO to HEAT
My nest items are online in Paper UI
items:
String home_away "Home/Away [%s]" <present> { nest="=[structures(Home).away]" }
DateTime Hallway_last_connection "Last Connection [%1$tm/%1$td/%1$tY %1$tH:%1$tM:%1$tS]" <calendar> {nest="<[thermostats(Hallway).last_connection]"}
String Hallway_hvac_mode "HVAC Mode" <climate> { nest="=[thermostats(Hallway).hvac_mode]" }
String Hallway_temperature_scale "Temperature Scale [%s]" { nest="<[thermostats(Hallway).temperature_scale]" }
Number Hallway_ambient_temperature_f "Ambient Temperature [%.1f °F]" <temperature> { nest="<[thermostats(Hallway).ambient_temperature_f]" }
Number Hallway_ambient_temperature_c "Ambient Temperature [%.1f °C]" <temperature> { nest="<[thermostats(Hallway).ambient_temperature_c]" }
Number Hallway_humidity "Humidity [%d %%]" <humidity> { nest="<[thermostats(Hallway).humidity]" }
Number Hallway_target_temperature_f "Target Temperature [%.1f °F]" <temperature> { nest="=[thermostats(Hallway).target_temperature_f]" }
Number Hallway_target_temperature_low_f "Minimum Temperature [%.1f °F]" <temperature> { nest="=[thermostats(Hallway).target_temperature_low_f]" }
Number Hallway_target_temperature_high_f "Maximum Temperature [%.1f °F]" <temperature> { nest="=[thermostats(Hallway).target_temperature_high_f]" }
Number Hallway_away_temperature_low_f "Minimum Away Temp. [%.1Hf °F]" <temperature> { nest="<[thermostats(Hallway).away_temperature_low_f]" }
Number Hallway_away_temperature_high_f "Maximum Away Temp. [%.1f °F]" <temperature> { nest="<[thermostats(Hallway).away_temperature_high_f]" }
Sitemap:
Frame label="Home" icon="house" {
Switch item=home_away mappings=[home="Home",away="Away"]
Frame label="Hallway Thermostat" {
Text item=Hallway_ambient_temperature_f visibility=[Hallway_temperature_scale=="F"]
Text item=Hallway_ambient_temperature_c visibility=[Hallway_temperature_scale=="C"]
Text item=Hallway_humidity
Switch item=Hallway_hvac_mode mappings=[heat="Heat",cool="Cool","heat-cool"="Auto",off="Off"]
Text item=Hallway_away_temperature_low_f visibility=[home_away=="away",home_away=="auto-away"]
Text item=Hallway_away_temperature_high_f visibility=[home_away=="away",home_away=="auto-away"]
Setpoint item=Hallway_target_temperature_f label="Target Temperature [%.1f °F]" minValue=50 maxValue=80 step=1 visibility=[Hallway_hvac_mode=="heat",Hallway_hvac_mode=="cool"]
Setpoint item=Hallway_target_temperature_low_f label="Minimum Temperature [%.1f °F]" minValue=50 maxValue=80 step=1 visibility=[Hallway_hvac_mode=="heat-cool"]
Setpoint item=Hallway_target_temperature_high_f label="Maximum Temperature [%.1f °F]" minValue=50 maxValue=80 step=1 visibility=[Hallway_hvac_mode=="heat-cool"]
Text item=Hallway_last_connection
