Rather than migrate following the guides from openhab 1 -> 2 I’ve decided to start from scratch and move over bit by bit.
I’ve configured nest and added nest.items. After restarting openhab I can see the items in paper ui, but I can’t figure out how I’m meant to get them into the control list.
As far as I can tell you can only control “things” and since the nest is a 1.x binding it has no things. Does that mean there is no way to get it on the UI?
I think I can create a sitemap and then control the nest from other UI options, but I wanted to try and stick with the new and shiny for now
Ta
Ross
