Has anyone had any luck with the nest sdm? I’ve set it up as instructed. I get the authorization code and input it. I get a notification from Google on my phone that someone is trying to access my account (obviously the sdm), I approve it and everything seems to work… except it doesn’t. I get a configuration error “failed to authorize SDM client. Check code or generate a new one.” I keep doing this but nothing works
I tried multiple times on <OH 3.2 and finally gave up until I tried it again with the new release. I just followed the binding instruction and surprisingly it worked in the first attempt
Same issue here:
Status: OFFLINE
CONFIGURATION_ERROR
Failed to authorize SDM client. Check the authorization code or generate a new one.
Steps I’ve taken but cannot get an ONLINE status:
- Pd the $5
- Created Project
- Got Project ID, Client ID, Client secret and successfully received authorization code and entered in OH3
- Set Google account to allow access to my Nest Project
The only thing that I didn’t do is when I got the authorization code it says to navigate to MyNest and past the code on the MyNest screen. MyNest was WWN prior to the newer SDM.
Am I missing something?
