Hi
I’m really hoping someone out there can offer some useful help/advice on an issue I’ve been struggling with for over a week now… Basically, I’m trying to dynamically update the membership of a group whenever an item in another group changes. The idea is that an item is added to a group called fgDownNetDevices whenever the item, which is a member of the group fgNetDevices changes from a state of ON to OFF. I’ve used some examples from this site to construct this but I just cannot get it to work as wanted but can’t see why…
Here’s my item file
Group:Switch:OR(ON,OFF) gRoot
Group:Switch:OR(ON,OFF) gFunction (gRoot)
Group gLocation (gRoot)
Group:Switch:OR(ON,OFF) gInformation (gFunction)
Group:Switch:OR(ON,OFF) fgNetDevices (gInformation)
Group gNetwork (gLocation)
Group fgDownNetDevices (gInformation)
Switch sRefreshON
Switch sTest_Network (gNetwork)
And my rule file
import java.util.concurrent.locks.ReentrantLock
var Timer Ontimer = null
var ReentrantLock lock = new ReentrantLock()
rule “Startup Timer”
System started
ONtimer = createTimer(now.plusSeconds(20)) [| sRefreshON.sendCommand(ON)]
rule “Populate Functional Groups”
System started
gRoot.allMembers.filter(s | s.name.endsWith(“Network”)).forEach[ item | fgNetDevices.addMember(item)]
rule “gRoot Update”
Item gRoot received update
if (!lock.isLocked) {
lock.lock()
try {
if (ONtimer.hasTerminated()) {
ONtimer = createTimer(now.plusSeconds(10)) [| sRefreshON.sendCommand(ON)]
} finally {
lock.unlock()
rule “fgDownNetDevices - Update”
Item sRefreshON received update
logInfo(“Rules”,”Group fgDownNetDevices about to be refreshed”)
fgDownNetDevices.members.forEach[ item | fgDownNetDevices.removeMember(item)]
fgNetDevices.allMembers.filter(s | s.state == OFF).forEach[ item | fgDownNetDevices.addMembers(item)]
The basic principal is that any update to any item should filter up through the hierarchical tree of the groups until the group gRoot receives an update. This should then trigger the rule “gRoot Update” which sends the command ON to the item sRefreshON. sRefreshON receiving an update should then trigger the rule fgDownNetDevices - Update” which should remove all members from the group fgDownNetDevices and then add any members of the group fgNetDevices whose state is OFF to the group fgDownNetDevices.
There is also a rule, “Populate Functional Groups”, that executes on startup that pre-populates the group fgNetDevices with any items where their name ends with the word Network. I’m pretty sure this rule is working fine as I can see the correct items within the group on my sitemap.
I have a test switch item called sTest_Network but when I change this switch item from ON to OFF on a sitemap it doesn’t appear in the group fgDownNetDevices.
If anyone can see what I’ve missed or done wrong I’d greatly appreciate the help
