I just move my whole system to a new install of openhab 2.5snapshot on a RPI3B+. Before that I was running openhab 2.4 (stable). I had no problems with Netamo…
After moving and reinstalled the binding, (not sure what version it is, it says 2.5snapshot). I have some issue getting string and values from some of the channels to show in sitemaps. And I really cant figure why.
The channels for the indoor module are:
Temptrend
MaxTemp
Location
The channel for the outdoor module is:
MaxTemp
All the other channels are working just fine…
I do receive an update in the log:
2019-04-01 03:27:45.949 [vent.ItemStateChangedEvent] - NetamoIndendoersTempTrend changed from down to stable
But in the sitemap it shows nothing.
This is my items file:
//Netamo indendørs
Number:Dimensionless NetamoIndendoersCo2 "Netamo Indendørs Co2 [%d %unit%]" <carbondioxide> { channel="netatmo:NAMain:75e7162d:70ee502727e6:Co2" }
Number:Temperature NetamoIndendoersTemperature "Netamo Indendørs Temperatur [%.1f %unit%]" <cu_heating> (Temperatur) { channel="netatmo:NAMain:75e7162d:70ee502727e6:Temperature" }
String NetamoIndendoersTempTrend "Netamo Indendørs Temperatur tendens" { channel="netatmo:NAMain:75e7162d:70ee502727e6:TempTrend" }
Number:Dimensionless NetamoIndendoersNoise "Netamo Indendørs Lyd Db [%d %unit%]" <soundvolume> { channel="netatmo:NAMain:75e7162d:70ee502727e6:Noise" }
Number:Pressure NetamoIndendoersPressure "Netamo Indendørs Tryg HPa [%.1f %unit%]" <cu_pressure> { channel="netatmo:NAMain:75e7162d:70ee502727e6:Pressure" }
String NetamoIndendoersPressTrend "Netamo Indendørs Tryg tendens" { channel="netatmo:NAMain:75e7162d:70ee502727e6:PressTrend" }
Number:Pressure NetamoIndendoersAbsolutePressure "Netamo Indendørs Absolut Tryg HPAa [%.1f %unit%]" <cu_pressure> { channel="netatmo:NAMain:75e7162d:70ee502727e6:AbsolutePressure" }
DateTime NetamoIndendoersMeasuretime "Netamo Indendørs Sidste opdatering [%1$tH:%1$tM %1$td.%1$tm.%1$tY]" <time> { channel="netatmo:NAMain:75e7162d:70ee502727e6:TimeStamp" }
Number:Dimensionless NetamoIndendoersHumidity "Netamo Indendørs Relativ fugtighed [%d %unit%]" <humidity> (Fugtighed) { channel="netatmo:NAMain:75e7162d:70ee502727e6:Humidity" }
Number NetamoIndendoersHumidex "Netamo Indendørs fugtighed føles som [%.0f]" <humidity> { channel="netatmo:NAMain:75e7162d:70ee502727e6:Humidex" }
Number:Temperature NetamoIndendoersHeatIndex "Netamo Indendørs Varme index [%.1f %unit%]" <cu_heating> { channel="netatmo:NAMain:75e7162d:70ee502727e6:HeatIndex" }
Number:Temperature NetamoIndendoersDewpoint "Netamo Indendørs Dugpunkt [%.1f %unit%]" <humidity> { channel="netatmo:NAMain:75e7162d:70ee502727e6:Dewpoint" }
Number:Temperature NetamoIndendoersMinTemp "Netamo Indendørs Mindste temperatur i dag" <cu_heating> { channel="netatmo:NAMain:75e7162d:70ee502727e6:MinTemp" }
Number:Temperature NetamoIndendoersMaxTemp "Netamo Indendørs Højeste temperatur i dag" <cu_heating> { channel="netatmo:NAMain:75e7162d:70ee502727e6:MaxTemp" }
DateTime NetamoIndendoersDateMinTemp "Netamo Indendørs Tid Mindste temperatur i dag: [%1$tH:%1$tM %1$td.%1$tm.%1$tY]" <time> { channel="netatmo:NAMain:75e7162d:70ee502727e6:DateMinTemp" }
DateTime NetamoIndendoersDateMaxTemp "Netamo Indendørs tid Højeste temperatur i dag: [%1$tH:%1$tM %1$td.%1$tm.%1$tY]" <time> { channel="netatmo:NAMain:75e7162d:70ee502727e6:DateMaxTemp" }
DateTime NetamoIndendoersLastStatusStore "Netamo Indendørs sidste opdatering: [%1$tH:%1$tM %1$td.%1$tm.%1$tY]" <time> { channel="netatmo:NAMain:75e7162d:70ee502727e6:LastStatusStore" }
Number NetamoIndendoersWifi "Netamo Indendørs Wifi status" <cu_wifi> { channel="netatmo:NAMain:75e7162d:70ee502727e6:WifiStatus" }
Location NetamoIndendoersLocation "Netamo Indendørs Lokation GPS kooridnator" { channel="netatmo:NAMain:75e7162d:70ee502727e6:Location" }
//Netamo udendørs
Number:Temperature NetamoUdendoersTemperature "Netamo Udendørs Temperatur [%.1f %unit%]" <cu_heating> (Temperatur) [ "CurrentTemperature" ] { channel="netatmo:NAModule1:75e7162d:0200002741f4:Temperature" }
String NetamoUdendoersTempTrend "Netamo Udendørs Temperatur tendens" { channel="netatmo:NAModule1:75e7162d:0200002741f4:TempTrend" }
Number:Dimensionless NetamoUdendoersHumidity "Netamo Udendørs Relativ fugtighed [%d %unit%]" <humidity> (Fugtighed) { channel="netatmo:NAModule1:75e7162d:0200002741f4:Humidity" }
DateTime NetamoUdendoersMeasuretime "Netamo Udendørs Sidste opdatering [%1$tH:%1$tM %1$td.%1$tm.%1$tY]" <time> { channel="netatmo:NAModule1:75e7162d:0200002741f4:TimeStamp" }
Number NetamoUdendoersHumidex "Netamo Udendørs fugtighed føles som [%.0f %%]" <humidity> { channel="netatmo:NAModule1:75e7162d:0200002741f4:Humidex" }
Number:Temperature NetamoUdendoersHeatIndex "Netamo Udendørs Varme index [%.1f %unit%]" <cu_heating> { channel="netatmo:NAModule1:75e7162d:0200002741f4:HeatIndex" }
Number:Temperature NetamoUdendoersDewpoint "Netamo Udendørs Dugpunkt [%.1f %unit%]" <humidity> { channel="netatmo:NAModule1:75e7162d:0200002741f4:Dewpoint" }
Number:Temperature NetamoUdendoersMinTemp "Netamo Udendørs Mindste temperatur i dag" <cu_heating> { channel="netatmo:NAModule1:75e7162d:0200002741f4:MinTemp" }
Number:Temperature NetamoUdendoersMaxTemp "Netamo Udendørs Højeste temperatur i dag" <cu_heating> { channel="netatmo:NAModule1:75e7162d:0200002741f4:MaxTemp" }
DateTime NetamoUdendoersDateMinTemp "Netamo Udendørs Tid Mindste temperatur i dag: [%1$tH:%1$tM %1$td.%1$tm.%1$tY]" <time> { channel="netatmo:NAModule1:75e7162d:0200002741f4:DateMinTemp" }
DateTime NetamoUdendoersDateMaxTemp "Netamo Udendørs tid Højeste temperatur i dag: [%1$tH:%1$tM %1$td.%1$tm.%1$tY]" <time> { channel="netatmo:NAModule1:75e7162d:0200002741f4:DateMaxTemp" }
DateTime NetamoUdendoersLastMessage "Netamo Udendørs sidste opdatering: [%1$tH:%1$tM %1$td.%1$tm.%1$tY]" <time> { channel="netatmo:NAModule1:75e7162d:0200002741f4:LastMessage" }
Switch NetamoUdendoersLowBattery "Netamo Udendørs Lav Batteri [%s]" <battery> { channel="netatmo:NAModule1:75e7162d:0200002741f4:LowBattery" }
Number NetamoUdendoersBatteryVP "Netamo Udendørs Batteri Niveau [%.0f %%]" <battery> (BatteriLevel) { channel="netatmo:NAModule1:75e7162d:0200002741f4:BatteryVP" }
Number NetamoIndendoersRfStatus "Netamo Udendørs Signal styrke [%.0f / 5]" <cu_wifi> { channel="netatmo:NAModule1:75e7162d:0200002741f4:RfStatus" }
And this is my sitemap:
sitemap vejr label="Vejret (Netamo)"
Frame label="Netamo indendørs" {
Text item=NetamoIndendoersTemperature {
Text item=NetamoIndendoersCo2 valuecolor=[<800="green",<1000="orange",<1400="red",>1399="maroon"]
Text item=NetamoIndendoersTempTrend
Text item=NetamoIndendoersNoise
Text item=NetamoIndendoersPressure
Text item=NetamoIndendoersPressTrend
Text item=NetamoIndendoersAbsolutePressure
Text item=NetamoIndendoersMeasuretime
Text item=NetamoIndendoersHumidity
Text item=NetamoIndendoersHumidex
Text item=NetamoIndendoersHeatIndex
Text item=NetamoIndendoersDewpoint
Text item=NetamoIndendoersMinTemp
Text item=NetamoIndendoersMaxTemp
Text item=NetamoIndendoersDateMinTemp
Text item=NetamoIndendoersDateMaxTemp
Text item=NetamoIndendoersLastStatusStore
Text item=NetamoIndendoersWifi
Text item=NetamoIndendoersLocation
Frame label="Mapview" {
Mapview item=NetamoIndendoersLocation label="Hjemme" icon="house" height=5
Frame label="Netamo udendørs" {
Text item=NetamoUdendoersTemperature {
Text item=NetamoUdendoersTempTrend
Text item=NetamoUdendoersHumidity
Text item=NetamoUdendoersMeasuretime
Text item=NetamoUdendoersHumidex
Text item=NetamoUdendoersHeatIndex
Text item=NetamoUdendoersDewpoint
Text item=NetamoUdendoersMinTemp
Text item=NetamoUdendoersMaxTemp
Text item=NetamoUdendoersDateMinTemp
Text item=NetamoUdendoersDateMaxTemp
Text item=NetamoUdendoersLastMessage
Text item=NetamoUdendoersLowBattery
Text item=NetamoUdendoersBatteryVP
Text item=NetamoIndendoersRfStatus
Anyone get any idea why these few channels doesn show, even though they update fine?
EDIT - just gone through my logfile. Seems like Location doesnt update at all. The others updates fine.
