Hi!
What is the latest status of the Netatmo 2.x binding regarding support for Welcome and Presence cameras?
From looking in the code there is no support for the Presence camera yet, however some references to Presence are there but the request scopes for Presence are not implemented.
Do you have to configure anything on your Netatmo application to get access to all request scopes? There is a possibility to configure a webhook URL there as well.
For Welcome there is some attempt made to get the Netatmo webhook API integrated to support immediate event notification, but what I’ve read is that it is hard to get info from Netatmo how it works and also that it requires to have a public IP-address to the openhab installation. Is that correct?
The README file for the Netatmo 2.x binding is not so verbose and would benefit of more examples of existing integrations/configuration that works.
If I would make an attempt to implement some support for the Presence camera since I own one, could I use the Welcome Swagger API for that? It looks like the Welcome and Presence cameras support the same API endpoints, with the exception that presence lacks the getlasteventof.
If the webhook integration is not a way forward, is there any other way of getting event’s pushed to openhab? I would like to have an event when an animal is visible to be able to turn a horn on e.g.
BR,
/Janne
