Open another browser with frontail log running, uninstall/reinstall the binding and see if there is any extra info in the logs as the binding is reinstalled. You can also set the binding to DEBUG or TRACE via the console and give the binding a restart. If your configuration is correct and nothing inside your firewall is blocking you then the logs should give you a hint to where the problem is.
I am facing a problem with the Netatmo Binding and the Weatherstation. It worked well for more than a year and since the 22nd of April I lost the outdoor sensor, got no updates on Temp and Hum since then.
I rebooted OH2 today and now I am missing all sensors beside the main Station where I still receive all data. I also resetted the main station, no change.
Also the Web interface is empty no data at all, logout/login didn’t help, only caused an e-mail that someone logged in. In the IOS App I get no forecast information but all sensors are delivering data.
The sensors in PaperUI have the state:
Status: OFFLINE Pending parent object initialization
But the mainstation and API is online
on the 22nd Apr. I find these lines in the log, they appeared the days before but never after.
2020-04-22 00:27:18.268 [hingStatusInfoChangedEvent] - 'netatmo:NAMain:home:inside' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Unable to connect Netatmo API : 500 Internal Server Error
2020-04-22 00:27:48.472 [hingStatusInfoChangedEvent] - 'netatmo:NAMain:home:inside' changed from OFFLINE (COMMUNICATION_ERROR): Unable to connect Netatmo API : 500 Internal Server Error to ONLINE
