Mhm i made a new clean instalation on my Raspberry Pi 2. Put the Certificate in the Keystore, used a new Netatmo Application + Keys but still gives me the Error… Everything seems to be perfect beside that its not working anymore.
2016-02-05 17:13:43.633 [ERROR] [g.openhab.io.net.http.HttpUtil] - Fatal transport error: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target 2016-02-05 17:13:43.672 [ERROR] [.service.AbstractActiveService] - Error while executing background thread Netatmo Refresh Service org.openhab.binding.netatmo.internal.NetatmoException: Could not refresh access token! If you see 'Fatal transport error: javax.net.ssl.SSLHandshakeException' above. You need to install the StartCom CA certificate and restart openHAB. See https://github.com/openhab/openhab/wiki/Netatmo-Binding#missing-certificate-authority for more information. at org.openhab.binding.netatmo.internal.NetatmoBinding$OAuthCredentials.refreshAccessToken(NetatmoBinding.java:769) ~[na:na] at org.openhab.binding.netatmo.internal.NetatmoBinding.execute(NetatmoBinding.java:116) ~[na:na] at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) ~[na:na] at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) ~[na:na]
Does someone else have this problem too?
okay i solved it, used the false keytool. there are two… please close or delete this thread
