I am trying to capture sensor data from Netatmo Healthy Home Coach.using Netatmo binding binding-netatmo - 2.2.0. I configured Netatmo Binding and Netatmo Bridge API. Both are shown with the status online. The problem is the binding does not catch any data (see screenshot below).
Netatmo API per manual call provides data correctly:
Thank you for the suggestion, Martin! Unfortunately, /var/log/openhab2/openhab.log has nothing sind 19.Dec, last record was:
017-12-19 23:35:34.643 [INFO ] [netatmo.handler.NetatmoBridgeHandler] - Initializing API Connection and scheduling token refresh every 5400s
/var/log/openhab2/events.log also does not have any fresh entries:
2017-12-23 12:53:29.446 [vent.ItemStateChangedEvent] - Online changed from ON to OFF
2017-12-23 12:53:29.482 [me.event.ThingUpdatedEvent] - Thing 'network:device:192_168_33_1' has been updated.
2017-12-23 14:24:31.955 [vent.ItemStateChangedEvent] - Online changed from OFF to ON
2017-12-23 14:24:31.977 [me.event.ThingUpdatedEvent] - Thing 'network:device:192_168_33_1' has been updated.
[20:54:21] pi@OpenHAB:/var/log/openhab2$ ls -ltr
total 144
-rwxrwxr-x 1 openhab pi 0 Dec 18 13:44 Readme.txt
-rw-rw-r-- 1 openhab pi 105144 Dec 20 00:35 openhab.log
-rw-rw-r-- 1 openhab pi 25178 Jan 7 22:25 events.log
-rw-rw-r-- 1 openhab openhab 847 Jan 9 20:42 audit.log
Can I trigger Netatmo somehow to make it try to query the sensor?
I do not know how one could trigger Netatmo. Are you configuring using the PaperUI or files? If you are using files, you should check that you have not changed the names of the things. See a similar problem here Issue with manual thing configuration in Netatmo binding
I guess you have tried to restart the binding and check events.log and openhab.log?
I am happy now ) In order to force the system to write something into traces, I restarted OpenHAB and checked the traces again - I found ‘boring’ normal entries:
