Netatmo bindings
  • Platform information:openhabian 4.2.2
    • Hardware: _CPUArchitecture/RAM/storage_raspberry pi 3 model b
    • OS: what OS is used and which version
    • Java Runtime Environment: _which java platform is used and what version_17
    • openHAB version:4.2.2
  • Issue of the topic: please be detailed explaining your issue
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
hi,this is a new openhabian’s installation on my rasp berry, i use un image of openhabian, some bindings are install automaticaly at the end of installation.
netatmo bindings is one of that.
i try to creat netatmo things.
first i create the account bridge and is ok the icon is green.
first question
then i try to create a wheater station think
i need to create netatmo wheater station i use the grafic interface for this, i insert bridge account the mac id of station, but don’t work.
second question
i try to create wellcome camera thing, but first i must create a house bridge, where ai find the ui thik?
thanks for your answere
Use auto discovery, all existing things will be created with proper settings for you.
hi thanks for your answer, i just try first, but the scan don’t find the things.
Dis you proceed to the oAuth registration process ?
There is a bug in OH4.2.2 and the the bridge is offline
netatmo-bridge-offline-99-of-time
