After installing the Netatmo Binding, I set everything up and the bridge also found all cameras that I use. However, they all are offline and say “Pending parent object initialization”. It’s been like this for about 30 minutes, and all the information I have entered to configure it is correct. There are similar topics, with the same error, however they are in older OH versions (I’m running OH3) or after migrating. The solution for this, was starting over, which I don’t want to do. Any ideas?
