Alright. It seems that you keep track on this for a while. Does it happen often that a single module is not updated? Or will all devices go down at the same time?
I think it happened two times for now that the Weather Station wasn’t updated any more. Everytime the indoor module as well as the outdoor module were effected at the time (as the outdoor module depends on the indoor module). Relay and Thermostat were down in the same way at another time. So there is no connection between the energy and the weather devices.
IT WORKS! GREAT!
Tks
Tonight it happened again, that the Relay and Thermostat stopped getting updated.
I had no internet connection in the night and since then all my Netatmo stuff (heating and weather) isn’t updated any more. There is nothing in the logs, all Things are online, but no updates. A reboot fixed it.
Hi, is there a solution for the new NA-valves obtainable? The description in the openhab binding-manual doesn’t fit for the new kind of valves.
Any solution?
Hi Gerd,
NetAtmo hasn’t even made the API for the new valves availabke yet… So for now we need to be patient…
Hi William,
the description on the Netatmo side says that they are done - valve module NRV …?
https://dev.netatmo.com/en-US/resources/technical/reference/energy/homesdata
Hi, are there any news to support Netatmo Smart Radiator Valves?
Now we have the API available.
After a long time without any problems, yesterday Netamto stopped refreshing data again.
This time with an error
2018-11-20 15:26:38.022 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.netatmo.internal.station.NAMainHandler.getNAThingProperty(NAMainHandler.java:63) ~[?:?]
at org.openhab.binding.netatmo.internal.handler.AbstractNetatmoThingHandler.lambda$3(AbstractNetatmoThingHandler.java:109) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:184) ~[?:?]
at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175) ~[?:?]
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:151) ~[?:?]
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:174) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:418) ~[?:?]
at org.openhab.binding.netatmo.internal.handler.AbstractNetatmoThingHandler.updateChannels(AbstractNetatmoThingHandler.java:106) ~[?:?]
at org.openhab.binding.netatmo.internal.handler.NetatmoDeviceHandler.updateChannels(NetatmoDeviceHandler.java:157) ~[?:?]
at org.openhab.binding.netatmo.internal.handler.NetatmoDeviceHandler.lambda$0(NetatmoDeviceHandler.java:84) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
The last successful update was ten minutes before.
Restarting the Binding fixed it.
I’m using openHAB 2.4.0 Build #1424; Netatmo Binding: 2.4.0.201811110923.
Same for me. Nearly at the same time. Occurred only once.
2018-11-20 15:25:28.266 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
06) ~[?:?]
Me too. Ones yesterday and ones today (UTC+2).
2018-11-20 16:35:01.399 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception
at org.openhab.binding.netatmo.handler.AbstractNetatmoThingHandler.lambda$3(AbstractNetatmoThingHandler.java:109) ~[?:?]
at org.openhab.binding.netatmo.handler.AbstractNetatmoThingHandler.updateChannels(AbstractNetatmoThingHandler.java:106) ~[?:?]
at org.openhab.binding.netatmo.handler.NetatmoDeviceHandler.updateChannels(NetatmoDeviceHandler.java:153) ~[?:?]
at org.openhab.binding.netatmo.handler.NetatmoDeviceHandler.lambda$0(NetatmoDeviceHandler.java:84) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
2018-11-21 17:08:31.243 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception
I submitted a fix for it this morning.
Another issue I like to share and talk about: I have the slight feeling the Netamo API is very often not reachable. Nothing which stops the binding from working but I saw a lot of errors (“Unable to connect Netatmo API : 500 Internal Server Error”) in the log. What about you? Was it similar for you in the past days? Or was the connection stable for you?
I cross fingers that the union of Legrande and Netatmo will not result in uncomfortable side effects for us.
The API is not verry stable. Right now I have since 18:42 a lot of errors. Not only 500
, also 404
and 503
Oh my … the Netatmo App does not work too.
Here the issue is from 6.21 PM CET. Still unsolved.
The Netatmo App was updated one hour ago. In the past few minutes I have more than 50 errors
51 Fehler in Openhab:
2018-11-22 20:28:12.121 [ERROR] [nternal.handler.NetatmoDeviceHandler] - Unable to connect Netatmo API : 502 Bad Gateway
Portal is back, so the App … but still some issues:
2018-11-22 20:42:29.282 [ERROR] [nternal.handler.NetatmoDeviceHandler] - Unable to connect Netatmo API : 502 Bad Gateway
edit: App back offline …
Dunno if I can paste a link from another forum, but … in case I will remove shortly:
https://forum.netatmo.com/viewtopic.php?f=5&t=14936
the issue seems coming from 2/3 days ago … maybe some changes on server side. I’ve seen few errors in my logs, but nothing like what we are experiencing right now … 2 hours down and counting …
edit: it seems working now. from 9.48 PM CET
