Hi, I’ve installed and configured successfully the netatmo binding.
Since I want to control my thermostat, can you provide some example of item and sitemap configuration ?
I didn’t found any example on the website…
Regards
Regards
@sihui any idea how i can declare the channel “heating status”. All other values are working, but if i declare that channel in items as a number or string i get no data.
This is item definition:
String stato_caldaia “Stato caldaia [%.1f]” {channel = “netatmo:NATherm1:b9XXXd7b:04XXXXXXXXcc8c:ThermRelayCmd”}
Defining as switch show ON! Also updates coming. Solved.
