Network Binding causes message DHCP request packet listener online
I installed the network binding and created a ping device that contacts www.google.de every 2 minutes.
I see in the log file every 6 minutes a message caused by this. I guess it is caused by the network binding, because it wasn’t there before.
What is causing these messages? Is there a way to get rid of them as they are spamming my log file?
2023-12-30 14:44:12.284 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 14:50:27.602 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 14:56:42.927 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 15:02:58.242 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 15:09:13.580 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 15:15:28.898 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 15:21:44.219 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 15:27:59.536 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 15:34:14.854 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 15:40:30.175 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 15:46:45.496 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 15:53:00.860 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 15:59:16.190 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 16:05:31.510 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2023-12-30 16:11:46.829 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
This is due to this line:
Ok, thanks. So there is no way to get rid of it :frowning:
Within shell:
log:set WARN org.openhab.binding.network.internal.dhcp.DHCPPacketListenerServer
This should update also you logging configuration and retain it over OH restarts.
And in case the level of this log is inappropriate for everybody, someone could propose a code change in Github.
I’m running OpenHAB in Docker on a Raspberry Pi. Where exactly do I have to enter this command?
I guess to ssh into the Pi and enter the command will not do the trick…
docker exec -it <container-name> bash then you can do ssh -p 8101 openhab@127.0.0.1; default password is habopen.
Alternatively you can expose port 8181 and connect using ssh client on host system.
There is also java client which you can call. I can’t remember exact path but it might be /openhab/runtime/bin/client.sh. If you will look for client.sh you will find it for sure as there is only one script with this name.
Thank you.
For some reason it did not work when executing the “log:set” command in a bash opened with “docker exec …”, but it did work with “ssh -p 8101 openhab@127.0.0.1
bernd@LM-21:~$ ssh pi@192.168.178.52
pi@192.168.178.52’s password:
pi@raspberrypi:~ $ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
1571aeb8ddc5 openhab/openhab:4.0.2 “/entrypoint gosu op…” 4 months ago Up 2 months (healthy) openhab400
pi@raspberrypi:~ $ docker exec -it 15 bash
root@raspberrypi:/openhab# log:set WARN org.openhab.binding.network.internal.dhcp.DHCPPacketListenerServer
bash: log:set: command not found
root@raspberrypi:/openhab# exit
exit
pi@raspberrypi:~ $ ssh -p 8101 openhab@127.0.0.1
Password authentication
Password:
openhab> log:set WARN org.openhab.binding.network.internal.dhcp.DHCPPacketListenerServer
openhab>
openhab> logout
Connection to 127.0.0.1 closed.
pi@raspberrypi:~ $ logout
Connection to 192.168.178.52 closed.
bernd@LM-21:~$
container name yo have to pass to docker exec is openhab400 or 1571aeb8ddc5. I dont see forwarded ports in your docker output so I can just guess, based on later output, that port 8101 might be forwarded (based on a fact that client ip is recognized as 192.168.178.52).
You can retry docker exec and then confirm that change was made through log:get org.openhab.binding.network.internal.dhcp.DHCPPacketListenerServer. If it will return WARN then you have access to openhab shell from your raspberry.
I thought that a part of the ContainerID, like 15 in my case, is good enough, when it can uniquely identify a container with it.
Anyways it did already work after ssh to 127.0.0.1!
No more info messages in my log file :slight_smile:
