I’m not sure if I am doing something wrong but I am getting high response times from local network devices. If I ping from the raspberry pi to the device I get sub ms response times, yet from the network binding I am getting high values. Anyone having issues with the network binding currently?
22:42:58.489 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'modemResponseTime' changed from 21 to 20
22:42:58.552 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'routerResponseTime' changed from 25 to 15
22:42:58.588 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'wirelessAPResponseTime' changed from 25 to 15
22:42:58.661 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'bbcResponseTime' changed from 38 ms to 29 ms
22:42:58.702 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'cloudflareDNSResponseTime' changed from 41 ms to 32 ms
22:42:58.739 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'googleDNSResponseTime' changed from 40 ms to 30 ms
- modem, router and wirelessAP are all local.
This is via a ping command:
pi@openhab:~ $ ping 192.168.1.2
PING 192.168.1.2 (192.168.1.2) 56(84) bytes of data.
64 bytes from 192.168.1.2: icmp_seq=1 ttl=63 time=0.348 ms
64 bytes from 192.168.1.2: icmp_seq=2 ttl=63 time=0.285 ms
64 bytes from 192.168.1.2: icmp_seq=3 ttl=63 time=0.305 ms
64 bytes from 192.168.1.2: icmp_seq=4 ttl=63 time=0.275 ms
^C
--- 192.168.1.2 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 135ms
rtt min/avg/max/mdev = 0.275/0.303/0.348/0.030 ms
