My Network bindings does not find anything even if my network is full of pingable devices.
I tried with OH windows version and it works very well but on pi this does not work.
If I try to add things manually the device is created in things but it does not connect.
arping at device IP works and arping is well installed in /usr/sbin/arping
Finally I recognised there was a mess between MQTT Mosquito running on pi and the OH MQTT binding that were entering in conflict.
I have uninstalled all the Bindings (MQQT and Network).
I have manulally deleted mqttmouquette.
I cleaned the cache
Sudo reboot
After I have reinstalled Network Bindings and it works perfect.
This problem is regarded as closed.
I spent a lot of time this night in reading and I guess that most of the issues are well documented in thi comunity together with fix suggestions. I love this
Thank you for the advise. Indeed I have mosquito running on pi and well working( can connect and hello world. All my sonoff connect.
Unlikely I sill have some issue with OH MQTT brrocker (bridge does not connect and I’m trying to understand why). But this is another issue and , if I will not find a solution on the community, I will post a new
