Hello, I Want to monitor some servers that are freezing from time to time. I want to use tcp connection check on a specific port. I have set up thing using:
network:servicedevice:test_serv [hostname="10.1.0.1", port=88, refreshInterval=30000]
Everything is working as expected. The only problem is if i stop the service on port 88 but the server is running the thing doesn’t change to OFF. The behavior i am looking for is the ting to change to OFF if it can not make successful connection to the 88.
