Hi OpenHab team
I need some help – got stuck
Using: Openhab2, Raspberry pi 3, Raspbian, Oracle java version “1.8.0_121”
Implemented “Network Binding” and it seems to be working fine. I have rules reacting when devices get online.
But noticed that I have trouble with discovering 3 devices, which all run windows 10.
I have no problem with doing a ping from the rasp to the win10 boxes.
Found this link:
So, I have executed this command:
pi@raspbox3:~ $ sudo setcap cap_net_raw=ep /opt/jdk1.8.0_121/bin/java
but afterwards, OH2 will not start:
pi@raspbox3:~ $ sudo service openhab2 status
● openhab2.service - openHAB 2 - empowering the
smart home
Loaded: loaded
(/usr/lib/systemd/system/openhab2.service; enabled)
Active: failed (Result: start-limit)
since Wed 2017-02-15 22:14:21 CET; 22s ago
Docs:
https://community.openhab.org
Process: 9434
ExecStop=/usr/share/openhab2/runtime/bin/stop (code=exited, status=127)
Process: 9335
ExecStart=/usr/share/openhab2/start.sh server (code=exited, status=127)
Main PID: 9335 (code=exited, status=127)
Feb 15 22:14:21 raspbox3 systemd[1]: Unit openhab2.service entered failed state.
Feb 15 22:14:21 raspbox3 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Feb 15 22:14:21 raspbox3 systemd[1]: Stopping openHAB 2 - empowering the smart home…
Feb 15 22:14:21 raspbox3 systemd[1]: Starting openHAB 2 - empowering the smart home…
Feb 15 22:14:21 raspbox3 systemd[1]: openhab2.service start request repeated too quickly, refusing to start.
Feb 15 22:14:21 raspbox3 systemd[1]: Failed to start openHAB 2 - empowering the smart home.
Also noticed that I can not run java:
pi@raspbox3:~ $ java -version
java: error while loading shared libraries: libjli.so: cannot open shared object file: No such file or directory
removing the ‘setcap’ fix’es the OH2, so it can run but still issues with win10.
sudo setcap -r /opt/jdk1.8.0_121/bin/java
Java™ SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot™ Client VM (build 25.121-b13, mixed mode)
Tried a variant on setcap but with same result.
sudo setcap cap_net_raw,cap_net_admin=eip
realpath /usr/bin/java
So, what should I do ?
