I’ve this .things:
Thing network:pingdevice:ping_vid[ hostname="192.168.123.1", retry="3", timeout="1000", refreshInterval="4000", use_system_ping="false", dhcplisten="false" ]
but the refresh value is ignored.
Also the log show this:
2018-03-15 14:54:25.180 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'retry': Can not set java.math.BigDecimal field org.openhab.binding.network.internal.NetworkHandlerConfiguration.retry to java.lang.String
2018-03-15 14:54:25.195 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'refreshInterval': Can not set java.math.BigDecimal field org.openhab.binding.network.internal.NetworkHandlerConfiguration.refreshInterval to java.lang.String
2018-03-15 14:54:25.202 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'timeout': Can not set java.math.BigDecimal field org.openhab.binding.network.internal.NetworkHandlerConfiguration.timeout to java.lang.String
The doc https://docs.openhab.org/addons/bindings/network/readme.html#thing-configuration show:
network:pingdevice:one_device [ hostname="192.168.0.64" ]
network:pingdevice:second_device [ hostname="192.168.0.65", retry=1, timeout=5000, refreshInterval=60000 ]
network:servicedevice:important_server [ hostname="192.168.0.62", port=1234 ]
Where is the problem?
Regards
