I am running OH 1.8.2 on Windows 10 pro. I wanted to use the Network Health binding as a presence detector but it is always detecting the devices as connected even when they aren’t.
If I turn a device off, it will recognize that in the next check, but all checks following this it shows an offline device as connected.
The phones all have static IP’s and I have tried both the device names and their IP’s. I have also tried both with and without the presence detection rule in the samples.
All of the threads I have seen on this issue have no resolution so I am assuming there still isn’t one?
Yeah I’ve tried that rule, actually the binding will check any ip you have written in the items anyway. Are you running Win 10? And does it correctly tell you when a device is connected or not everytime?
No, Raspbian on Raspberry Pi. On RPi it’s working fine, but as you can see in the issue @watou has mentioned, there are problem with Windows, I wasn’t aware of that.
