[Network] [snapshot] Inbox being filled and emptied
Yesterday I was checking out the network binding, however I observed something really strange imho, it seems that after the discovery is finished the complete inbox is being emptied again.
During discovery I see things popping up, more less like I would expect.
But suddenly this list starts shrinking again until in the end all network items are removed from the inbox, I can observe the removing from the events.log but have no idea why. The only thing I found when looking at the code is that old results are removed before a new scan starts, but checking the log carefully no new scan is started.
Do other people observe the same behaviour?
@David_Graeff
Background:
I’m running a docker with the snapshot of 201709240307
That’s intended. Because the network binding causes a mess in the inbox, politely spoken, all entries have a TTL.
Cheers David
It seems really short time to respond, as soon as it is ready (a lot of docker networks) it starts deleting the first ones. Would a timeout of 10 minutes or half an hour sound reasonable to you?
Yes 10min or so should do it. I would like it if paperui would show an indicator about when an item will be pruned.
See PR in https://github.com/openhab/openhab2-addons/pull/2773
I created an issue for that https://github.com/eclipse/smarthome/issues/4391
According to @Kai the TTL was not intended for this, so I opened an issue https://github.com/openhab/openhab2-addons/issues/2776 feel free to suggest anything there.
