yes you’right. I just want to use the output of the pid directly for the zwave eurotronic dimmer.
if this will not work, ok virtual items are also OK.
But my problem actually is, that I can not see any output of the pid on the logs.
I can see changing of debug items for p, I, d and error.
but no sent command to my dimmer item.
that’s confusing
hmm. the pid controller, or the rule that uses the pid controller has an item to send the command to.
in my case I want to use the eurotronic dimmer item as the item to sent to.
the setpoint comes from the user
one question again.
is there a way to disable the pod controller or does this make sense.
in my rules for example if I’m leaving home i switch off my. heating regulator.
but the pid controller is still running, producing output in the logs. so. is there a way to disable it until I’m coming back home?
Best way is to lower the setpoint to the desired value if you’re not at home. I don’t see any reason for disabling or pausing the controller when you leave as physics will continue.
ok in generally you’re right.
but in this case the pid controller still produces logs.
I just want to prevent filling my Logs with all this changes because they make no sense if I’m not at home.
and even if I lower the temperature, the pid will not reach the target, because the actuator is off…
Ok, but if there is no way, that I will leave it as it is now.
thanks
With all honesty I don’t really understand why you have problem with that.
Usually logs will rotate so if you will set it to like static 10MB size + rotate of 5 files - you will not use more space than that.
Second thought is that typically you should forget about it and don’t look inside at all unless issue will occur. In my case I barely look inside and when I do - I’ll would search for something specific.
~60 lines of logs per hour shouldn’t be that much and if you are affraid about wear of SD card then solution is to create in memory drive that will host data that can vanish (RAM disk).
That’s my opinion - I work at company where we generate up to 10TB of logs daily out of few hundred different apps so few lines here doesn’t bother me at all.
I don’t really have any thought how to disable those completely. There is no off option in controller.
I’m having some difficulty using the Derivative Gain Parameter.
When I set it to other than 0, and the error (eInspector) is positive, the output increases by kp*error + kd*error.
(for simplicity, ki = 0)
Isn’t this wrong? Shouldn’t the output be kp*error - kd*error.
I believe that is the only way that the derivative can slow down the change.
Or am I misunderstanding something?
I must admit I struggle to understand the formal representations of PID’s on the web so I cannot give a concrete example, but as I said, the derivative should slow the change, and I’m afraid it doesn’t
Allowing kd to be negative would give a chance to play.
Can you think of an easy way I could do that?
It works in the Code page unless you then try to modify anything in the Design page. It then complains about the negative kd when it validates the input.
