[New Binding] Eufy Doorbell
Hey there,
I wanted to activate my lights when some motion is detected, so I routed the Events directly to the items over Openhab-Rest-API.
Have a look at my python script: (I know, it’s not perfect. It’s my first pythonscript, maybe someone can optimize it :wink: )
from ast import Continue
import asyncio
from math import e
import websockets
import json
import logging as LOG
import coloredlogs
from openhab import OpenHAB
import os
# Configure logging
LOG.basicConfig(level=LOG.INFO, format='%(asctime)s %(levelname)s %(message)s',
                        datefmt='%d-%b-%y %H:%M:%S')
coloredlogs.install(isatty=True)
rest_url = os.environ.get('OPENHAB')
eufy_security_ws_url = os.environ.get('EUFY_SECURITY_WS')
if rest_url is None:
    LOG.error("OPENHAB environment variable not set. Falling back to default")
    rest_url = "http://redqueen:8081/rest"
if eufy_security_ws_url is None:
    LOG.error("EUFY_SECURITY_WS environment variable not set. Falling back to default")
    eufy_security_ws_url = "ws://redqueen:3000"
# Connect OpenHAB Rest API
openhab = OpenHAB(rest_url)
# Listen to events
async def listen():
    while True:
        try:
            async with websockets.connect(eufy_security_ws_url) as ws:
                #initialize connection
                LOG.info("Command: Initialize connection")
                await ws.send(json.dumps({
                    "messageId": "api-schema-id",
                    "command": "set_api_schema",
                    "schemaVersion": 9,}))
                answer = await ws.recv()
                proceed_init(answer)
                #Start listening on events
                LOG.info("Command: Start listening")
                    "messageId": "start_listening",
                    "command": "start_listening",}))
                proceed_answer(answer)
                # endless loop for receiving messages
                while True:
                    msg = await ws.recv()
                    process_event(msg)
        except ConnectionResetError:
            LOG.error("ConnectionResetError, reconnecting in 10 seconds...")
            await asyncio.sleep(10)
            Continue
        except websockets.ConnectionClosedError:
            Continue
        except websockets.ConnectionClosedOK:
            Continue
        except Exception as error:
            Continue
def proceed_init(answer):
    obj = json.loads(answer)
    try:
        LOG.info(f"Success! driverVersion{obj['driverVersion']}, serverVersion: {obj['serverVersion']}")
    except KeyError:
        null = 0
# process the answer
def proceed_answer(answer):
    try:
        success = obj["success"]
        if success == True:
            LOG.info("Success!")
        else:
            LOG.error("Error!")
    except KeyError:
        Continue
# process the message
def process_event(message):
    obj = json.loads(message)
    try:
        if obj["type"] == "event":
            eventname = obj["event"]["event"]
            if str(eventname) == "motion detected" or str(eventname) == "person detected":
                LOG.info(f"Motion detected: {obj['event']['event']}, Device: {obj['event']['serialNumber']}, State: {obj['event']['state']}")
                item = openhab.get_item(obj['event']['serialNumber'])
                state = obj['event']['state']
                if state == True:
                    item.on()
                else:
                    item.off()
        elif obj["type"] == "result":
            for station in obj["result"]["state"]["stations"]:
                LOG.info(f"Station online: {station['serialNumber']}, Name: {station['name']}")
            for device in obj["result"]["state"]["devices"]:
                LOG.info(f"Device online: {device['serialNumber']}, Name: {device['name']}")
        else:
            Continue
    except KeyError:
        Continue
# Start the loop
loop = asyncio.get_event_loop()
try:
   # loop.create_task(listen())
    asyncio.ensure_future(listen())
    loop.run_forever()
except KeyboardInterrupt:
    pass
finally:
    print("Closing Loop")
    loop.close()
UPDATE: Script Updated, running stable!
Regards,
Daniel
That’s what I have in mind too! This add the value of a “better motion detector for automations” to the Eufy products. By doing so we could even distinguish between pets, humans or vehicles triggering the detection.
Many thanks for sharing!
What’s the status of a binding? I’, looking for support of the sirene
It is possible to connect a eufy doorbell?
I bought an S230 doorbell. It would be great to connect it to openhab and create rules.
