Hi Arne,
thanks for the help. I get now the measured temp values from my FHT80b devices.
Thanls also for the latest version.
I installed it.
After I installed the binding I resume the binding but there are only read timeouts. Also I tried to pause, unplug the CUL, plug the CUL again in and start the binding again. But there are only read timeouts. It seems that the CUL is not reacting on the Iinitialization after the X61 command. Only if I activate the stick within a screen session it will work. (i only type X61 within the screen session and wait for the first message of the FHT devices)
What do you exactly mean with the com logging? I activated the option “Log Serial Port Data”
Do you mean the CUL_SpswBridgeHandler file? Or another log file? If so: How can I activate and get it?
About the cronPattern: I tried 0 15 13 ? * MON *, but in the log file appears then an error message. But Cron Pattern itself is working (the CUL pings the FHT80B device at the given time)
[ERROR] [d.i.e.f.h.RadiatorFht80bHandler ] - handleConfigurationUpdate called: cronPatternDevicePing = 0 15 13 ? * MON *
See attached the CUL_SpswBridgeHandler for the communication with read timeouts (witgout activating the stick within a screen session:
@2024-01-08T20:36:17.296905026Z SP call opend: "/dev/ttyUSB0" (speed=9600 bps, dataBits=DB_8, stopBits=1 sb, partity=NONE, flowControl=[])
@2024-01-08T20:36:17.297530193Z SP call setSpeed: 38400 bps
@2024-01-08T20:36:17.299615489Z SP return setSpeed
@2024-01-08T20:36:17.299854675Z SP call setDataBits: DB_8
@2024-01-08T20:36:17.302092878Z SP return setDataBits
@2024-01-08T20:36:17.302233656Z SP call setParity: NONE
@2024-01-08T20:36:17.304557730Z SP return setParity
@2024-01-08T20:36:17.304649138Z SP call setStopBits: 1 sb
@2024-01-08T20:36:17.307057008Z SP return setStopBits
@2024-01-08T20:36:17.307145489Z SP call setFlowControl: []
@2024-01-08T20:36:17.309596526Z SP return setFlowControl
@2024-01-08T20:36:17.309708638Z SP call setTimeouts: (interByteReadTimeout=100, overallReadTimeout=60000, overallWriteTimeout=1000)
@2024-01-08T20:36:17.309873286Z SP return setTimeouts
@2024-01-08T20:36:17.310510434Z CH call write: ""
@2024-01-08T20:36:17.310482934Z @2024-01-08T20:36:17.310713267Z CH returnCH call read
write duration: PT0.000202833S
@2024-01-08T20:36:17.311224915Z CH call write: "X61\r\n"
@2024-01-08T20:36:17.311468101Z CH return write duration: PT0.000243186S
@2024-01-08T20:36:17.411898082Z CH call write: "T011101\r\n"
@2024-01-08T20:36:17.412322415Z CH return write duration: PT0.000424333S
@2024-01-08T20:37:17.316501380Z CH return read-timeout: buff.position=0, buff.remaining=64 " duration: PT1M0.006018446S
@2024-01-08T20:37:17.317666713Z CH call read
@2024-01-08T20:38:17.378171122Z CH return read-timeout: buff.position=0, buff.remaining=64 " duration: PT1M0.060504409S
@2024-01-08T20:38:17.378747696Z CH call read
@2024-01-08T20:39:17.435861919Z CH return read-timeout: buff.position=0, buff.remaining=64 " duration: PT1M0.057114223S
@2024-01-08T20:39:17.436717882Z CH call read
@2024-01-08T20:40:17.497378143Z CH return read-timeout: buff.position=0, buff.remaining=64 " duration: PT1M0.060660261S
@2024-01-08T20:40:17.498318624Z CH call read
@2024-01-08T20:41:17.544189866Z CH return read-timeout: buff.position=0, buff.remaining=64 " duration: PT1M0.045871242S
@2024-01-08T20:41:17.545119607Z CH call read
@2024-01-08T20:42:17.597487182Z CH return read-timeout: buff.position=0, buff.remaining=64 " duration: PT1M0.052367575S
@2024-01-08T20:42:17.598480793Z CH call read
@2024-01-08T20:43:17.655873128Z CH return read-timeout: buff.position=0, buff.remaining=64 " duration: PT1M0.057392335S
@2024-01-08T20:43:17.656729906Z CH call read
@2024-01-08T20:44:17.703010425Z CH return read-timeout: buff.position=0, buff.remaining=64 " duration: PT1M0.046280519S
@2024-01-08T20:44:17.703472481Z CH call read
@2024-01-08T20:45:17.761906667Z CH return read-timeout: buff.position=0, buff.remaining=64 " duration: PT1M0.058434186S
@2024-01-08T20:45:17.762368390Z CH call read
@2024-01-08T20:46:17.807593187Z CH return read-timeout: buff.position=0, buff.remaining=64 " duration: PT1M0.045224797S
@2024-01-08T20:46:17.808073483Z CH call read
See also attached the communication after I activated the stick within a screen session (I only type in the X61 command within the screen session. After that I resume the bridge ):
2024-01-08T20:56:32.339549654Z SP call opend: "/dev/ttyUSB0" (speed=38400 bps, dataBits=DB_8, stopBits=1 sb, partity=NONE, flowControl=[])
@2024-01-08T20:56:32.340465599Z SP call setSpeed: 38400 bps
@2024-01-08T20:56:32.341450432Z SP return setSpeed
@2024-01-08T20:56:32.341705710Z SP call setDataBits: DB_8
@2024-01-08T20:56:32.344009321Z SP return setDataBits
@2024-01-08T20:56:32.344494284Z SP call setParity: NONE
@2024-01-08T20:56:32.346545024Z SP return setParity
@2024-01-08T20:56:32.346894302Z SP call setStopBits: 1 sb
@2024-01-08T20:56:32.348981969Z SP return setStopBits
@2024-01-08T20:56:32.349297487Z SP call setFlowControl: []
@2024-01-08T20:56:32.351510339Z SP return setFlowControl
@2024-01-08T20:56:32.351854099Z SP call setTimeouts: (interByteReadTimeout=100, overallReadTimeout=60000, overallWriteTimeout=1000)
@2024-01-08T20:56:32.352256024Z SP return setTimeouts
@2024-01-08T20:56:32.353694413Z CH call write: ""
@2024-01-08T20:56:32.354083784Z CH return write duration: PT0.000389371S
@2024-01-08T20:56:32.354911006Z CH call write: "X61\r\n"
@2024-01-08T20:56:32.355524302Z CH return write duration: PT0.000613296S
@2024-01-08T20:56:32.355813395Z CH call read
@2024-01-08T20:56:32.456344024Z CH call write: "T011101\r\n"
@2024-01-08T20:56:32.456743895Z CH return write duration: PT0.000399871S
@2024-01-08T20:56:39.716797965Z CH return read: "T1E6000A000FC\r\n" duration: PT7.36098457S
@2024-01-08T20:56:39.718117279Z ExR "FHT Message: {protocol : FHT, housecode : 3096, command : VALVE, description : 0xa0, mode : END_OF_SYNC_SEQUENCE, repeated : true, position : 0.0, allowLowBatteryBeep : false}, signal strength: ->
@2024-01-08T20:56:39.721888390Z CH call read
