hi @hairdresser - I have recently moved into an office with these devices and I would like to access them over their BLE interface - is your underlying code available anywhere?
Hello @hairdresser, I’m watching your project with interest. In particular I would like to see a implementation that works with MQTT so that it can easily integrate with other home automation software such as Home Assistant. If your project is openhab specific, do you think it would be possible to use this (ESP32 BLE MQTT BI-DIRECTIONAL) project with some of your communication code?
Thanks for information on this project! I actually love MQTT and was looking in this direction as well because bluetooth implementation in java is not super portable.
The way the protocol works is a serial port UART over BLE characteristics, using a write without response characteristic and a notify characteristic for responses. Are notify characteristics supported ?
I dont have ESP32 so I ll try to get one. That would actually make my life easier !!
Hum - this is very different and with different dependencies.
I am slowly progressing as I currently have problems with my Bluetooth setup (my adapter died!).
But I am happy to have help from experienced OpenHab developer
Anyway, the Bluez/DBus library is working far better than TinyB !
IMHO from user’s point of view, it’s logical to expect Daikin binding to work with all Daikin devices.
OTOH, if they are really so different, existing Daikin could be renamed to DaikinWifi and the new one could be DaikinBLE
Guys,
Just to give you an update, it starts being working and I’m super happy so far! It was a bit hard because I was developing both the bridge and the binding - but here is the status as of now:
I can help, but your work would need to be separated into two separate projects:
A new dbus bluetooth adapter for the official bluetooth plugin.
It should be possible to use bluez-dbus library you are currently using to implement the bulk of it. The hardest part would be making sure to exclude most of the transient dependencies of that library since openHab has their own versions of a lot of them.
If you want to get started with this you can use the bluez binding as a coding template of sorts, I’m sure there is quite a lot of overlap. But I would first wait until PR#7129 gets merged since it would simplify the amount of work you would need to do.
The Daikin madoka controller BLE binding.
Right now I assume you are using the bluez-dbus library directly, so you would need to change your code to use the official bluetooth plugin api instead.
Also, I would suggest reaching out to the code owner of the official Diakin binding and see if it might be worthwhile to include your code as part of that binding depending on how much overlap there is.
I have started all my development with the 2 separate bindings already. One dbus-bluez that implements the existing interfaces of Bluetooth, and the daikin ble that uses the Bluetooth bridge binding.
I think there is no overlap at all with the existing daikin binding as the technology and hardware is different, as well as communication protocol. So beside of the « daikin » name, the 2 bindings don’t share anything.
As for dependencies, I don’t embed any library in my projects, I use osgi version of dbus-bluez as my only dependency.
I am very keen to help and give back to the community as I strongly believe that openhab is today the best home automation framework.
From the protocol you’ve posted it looks like you can use the AM43 binding as a template for implementing your Daikin-BLE binding. They way that you interact with the AM43 is basically an emulated serial protocol over bluetooth, just like the Daikin. You should probably copy the AM43 communication framework which I found after and trial and error to deal with some of the more fragile aspects of the underlying bluez stack.
Edit: That and I built the framework to be as robust as possible.
