For me it works stable but I’d like to have feedback from other owners.
The binding supports retrieving data directly from the device via local network.
It currently supports all of the data which can be retrieved from the device.
I would like to use your Liquid Check binding, but I am not experienced enough in openHAB to do so.
Can you give me a short tutorial how to integrate your binding into openHAB 3.4.2?
There is no restart required, the binding will be added automatically to your openHAB instance.
For setting up the binding you can refer to the README.md in the source code that I’ve linked in my previous post.
Hey,
this seems to be the wrong folder.
If you are using linux then the folder should be something like:
/srv/openhab-addons
or
/usr/share/openhab/addons
or you can try this:
I am sorry, but I still have a further question.
Besides the item Measure which can be changed from OFF to ON all the other items have value NULL, i.e. they seem to have no connection to the device.
What could be the reason? I am using Liquid Check revision C5 with firmware version 1.71.
the response seems not to be different from the one with which I developed the binding.
So the binding should work correctly.
I guess it’s just the refresh interval that you have to wait for.
