Okay I am a little lost on this. I have the hueemulation up and running. I can see the logs on openhab when I scan for devices on the amazon echo app. I think what I am getting wrong is where I am putting the tag. i am going into the org.eclipse.smarthome.core.thing.link.ItemThingLink.json in the /var/lib/openhab2/jsondb and setting the tag in the []. This is of course on a rpi3. Any help is appreciated.
Edit:. OK got it sorted… Had to create an echo.items file. All is well with the world.
sorry to re-open this topic but i could not see a solution for the problem mentioned in the beginning.
I actually run OH2 on the latest Snapshot (2.1.0 build 909) and have the same 1 “degree” onset if i set one of my items, tagged as TargetTemperature, to something like 25. where its getting then set to 24.
The only solution is to receive the value to a dummy item and in the rule substract 1 from the received value. Then send the new value to the actual item.
Maybe I missed it but is there a way to allocate an item to a virtual hue group/room (like with the hue App) so that I can say “Alexa, switch on the light in xxx” where xxx is the group or room name?
Currently I name every item so special that the name is so unique and toggles the exact item. However as light, sonos, etc is available in several rooms it would be more natural to combine the item name (like Light) with the location (like Livingroom) in one spoken sentence (Alexa, switch the Light in Livingroom on).
Hi, so far the Hue Emulator works fine with third party devices like switches and so on. But not so well with a second real hue bridge and real hue bulbs that are connected to that real hue bridge.
I have a Harmony hub and a real hue bridge. Unfortunately Harmony allows only to pair it with one hue bridge. To controll everything this must be the Hue Emulator bridge. Unfortunately the emulated bridge does not seem to proxying through the real hue devices that are connected to the real hue bridge.
I can set up the real bulbs as “Lighting” items in OpenHab:
But this doesn’t give me the same behavior und functionality as when is use the directly with Harmony and the real hue bridge.
For example when i turn on the bulbs with the Harnomy connected to the real hue bridge the bulbs have the same color as wehn I turned the off.
Do I turn them on connected to the Hue Emulator the Color is always white and they are undimmed at 100%.
BTW: I have the same behavior when I controll them with an Amazon Echo.
I’m trying to use the Hueemulation instead of the “official” Alexa Skill concept to enable a voice control over my Echo Dot.
Environment: Raspberry Pi 3 with OpenHABian and OpenHAB 2.1.0-1
I installed the io by moving the jar file into the addons folder (v2.0.0).
I taged my devices like explained in the readme.md of the master branch Switch KT_LT_M_State "Küchenlicht" (light) [ "Lighting" ] { channel="homematic:HM-LC-Sw1PBU-FM:ccu:LEQ0215535:1#STATE" }
Always when I search with alexa for devices I get the following exception and no devices are found by Alexa: 2017-07-12 23:29:49.425 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /api/cLVHVFRbsRt9Rap2KGP4XWaAO5aUZUGGcL6tBqmh java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String at java.lang.String.compareTo(String.java:111)[:1.8.0_121] at java.util.TreeMap.getEntry(TreeMap.java:352)[:1.8.0_121] at java.util.TreeMap.remove(TreeMap.java:603)[:1.8.0_121] at org.openhab.io.hueemulation.internal.HueEmulationServlet.getHueDevices(HueEmulationServlet.java:576)[193:org.openhab.io.hueemulation:2.0.0.201611112128] at org.openhab.io.hueemulation.internal.HueEmulationServlet.apiDataStore(HueEmulationServlet.java:433)[193:org.openhab.io.hueemulation:2.0.0.201611112128] at org.openhab.io.hueemulation.internal.HueEmulationServlet.service(HueEmulationServlet.java:258)[193:org.openhab.io.hueemulation:2.0.0.201611112128] at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)[18:javax.servlet-api:3.1.0] at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[81:org.eclipse.jetty.servlet:9.2.19.v20160908] at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[81:org.eclipse.jetty.servlet:9.2.19.v20160908] at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0] at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[80:org.eclipse.jetty.server:9.2.19.v20160908] at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[79:org.eclipse.jetty.security:9.2.19.v20160908] at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[80:org.eclipse.jetty.server:9.2.19.v20160908] at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[80:org.eclipse.jetty.server:9.2.19.v20160908] at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0] at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[81:org.eclipse.jetty.servlet:9.2.19.v20160908] at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[80:org.eclipse.jetty.server:9.2.19.v20160908] at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[80:org.eclipse.jetty.server:9.2.19.v20160908] at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[80:org.eclipse.jetty.server:9.2.19.v20160908] at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0] at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[80:org.eclipse.jetty.server:9.2.19.v20160908] at org.eclipse.jetty.server.Server.handle(Server.java:499)[80:org.eclipse.jetty.server:9.2.19.v20160908] at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[80:org.eclipse.jetty.server:9.2.19.v20160908] at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[80:org.eclipse.jetty.server:9.2.19.v20160908] at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[71:org.eclipse.jetty.io:9.2.19.v20160908] at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v20160908] at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v20160908] at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
Please help. I have Google Home Hue Emulator running and paired. But I don’t see my Z-wave devices in Google Home app. http://openhabian/api/discover.xml displays: {“lights”:{}}
Reading the README it says. Device tagging. How do I do it?
