You can see after the reboot and the first connection to the websocket, an error is thrown with the org.xml.sax.SAXParseException element type: actino Is this the root cause?
Should this be action?
I’ll be back online this evening.
Thanks for your help!
-Chase
2017-03-19 12:48:35.211 [DEBUG] [org.openhab.binding.isy ] - BundleEvent STOPPED - org.openhab.binding.isy
2017-03-19 12:48:35.236 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2017-03-19 12:48:35.265 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2017-03-19 12:48:35.398 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2017-03-19 12:48:35.486 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2017-03-19 12:49:58.542 [INFO ] [ore.internal.i18n.LocaleProviderImpl] - Locale set to en_US
2017-03-19 12:50:22.246 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2017-03-19 12:50:24.330 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-03-19 12:50:24.536 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-03-19 12:50:24.865 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-03-19 12:50:24.872 [DEBUG] [org.openhab.binding.isy ] - BundleEvent STARTING - org.openhab.binding.isy
2017-03-19 12:50:24.883 [DEBUG] [org.openhab.binding.isy ] - BundleEvent STARTED - org.openhab.binding.isy
2017-03-19 12:50:25.022 [DEBUG] [org.openhab.binding.isy ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=bindin$
2017-03-19 12:50:25.391 [DEBUG] [org.openhab.binding.isy ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=279, service.bu$
2017-03-19 12:50:25.413 [DEBUG] [inding.isy.handler.IsyHandlerFactory] - registerIsyBridgeDiscoveryService(): Bridge Handler - org.openhab.binding.isy.handler.IsyBridgeHandler@1a5fa1a,$
2017-03-19 12:50:25.502 [DEBUG] [binding.isy.handler.IsyBridgeHandler] - initialize called for bridge handler
2017-03-19 12:50:26.449 [DEBUG] [sy.internal.IsyWebSocketSubscription] - Socket Connected: WebSocketSession[websocket=JettyListenerEventDriver[org.openhab.binding.isy.internal.IsyWebSo$
2017-03-19 12:50:26.452 [INFO ] [sy.internal.IsyWebSocketSubscription] - Connecting to :ws://x.x.x.x:xxxx/rest/subscribe
2017-03-19 12:50:26.453 [DEBUG] [sy.internal.IsyWebSocketSubscription] - in finally in IsyWebSocketSubscription
2017-03-19 12:50:26.535 [ERROR] [sy.internal.IsyWebSocketSubscription] - parse exception
org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 91; The element type "actino" must be terminated by the matching end-tag "</actino>".
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:257)[:1.8.0_112]
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:339)[:1.8.0_112]
at org.openhab.binding.isy.internal.IsyWebSocketSubscription.parseXml(IsyWebSocketSubscription.java:126)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.openhab.binding.isy.internal.IsyWebSocketSubscription.onWebSocketText(IsyWebSocketSubscription.java:111)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.events.JettyListenerEventDriver.onTextMessage(JettyListenerEventDriver.java:128)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.message.SimpleTextMessage.messageComplete(SimpleTextMessage.java:69)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.events.AbstractEventDriver.appendMessage(AbstractEventDriver.java:65)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.events.JettyListenerEventDriver.onTextFrame(JettyListenerEventDriver.java:122)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.events.AbstractEventDriver.incomingFrame(AbstractEventDriver.java:161)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.WebSocketSession.incomingFrame(WebSocketSession.java:308)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.extensions.ExtensionStack.incomingFrame(ExtensionStack.java:214)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.Parser.notifyFrame(Parser.java:220)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.Parser.parse(Parser.java:258)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.client.io.WebSocketClientConnection.onOpen(WebSocketClientConnection.java:92)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.client.io.UpgradeConnection.upgradeConnection(UpgradeConnection.java:306)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.client.io.UpgradeConnection.read(UpgradeConnection.java:243)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.client.io.UpgradeConnection.onFillable(UpgradeConnection.java:163)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[72:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_112]
2017-03-19 12:50:26.585 [ERROR] [sy.internal.IsyWebSocketSubscription] - parse exception
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.readParse(AbstractWebSocketConnection.java:632)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:480)[181:org.openhab.binding.isy:2.1.0.201703172158]
2017-03-19 12:50:26.598 [WARN ] [clipse.jetty.websocket.common.Parser] -
org.eclipse.jetty.websocket.api.ProtocolException: Unknown opcode: 6
at org.eclipse.jetty.websocket.common.Parser.parseFrame(Parser.java:327)[181:org.openhab.binding.isy:2.1.0.201703172158]
at org.eclipse.jetty.websocket.common.Parser.parse(Parser.java:254)[181:org.openhab.binding.isy:2.1.0.201703172158]
2017-03-19 12:50:26.601 [ERROR] [sy.internal.IsyWebSocketSubscription] - Error with websocket communication
2017-03-19 12:50:26.677 [DEBUG] [sy.internal.IsyWebSocketSubscription] - Socket Closed: [1002] Unknown opcode: 6
2017-03-19 12:50:27.298 [DEBUG] [sy.internal.IsyWebSocketSubscription] - Control: _4, Action: 5, Node:
2017-03-19 12:50:27.300 [WARN ] [clipse.jetty.websocket.common.Parser] -
org.eclipse.jetty.websocket.api.WebSocketException: java.lang.NullPointerException
at org.eclipse.jetty.websocket.common.Parser.parse(Parser.java:280)[181:org.openhab.binding.isy:2.1.0.201703172158]
Caused by: java.lang.NullPointerException
at org.eclipse.jetty.websocket.common.Parser.parse(Parser.java:259)[181:org.openhab.binding.isy:2.1.0.201703172158]
... 8 more
2017-03-19 12:50:27.312 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
... 8 more
2017-03-19 12:50:27.347 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - Unexpected thread death: org.eclipse.jetty.util.thread.QueuedThreadPool$3@281812 in WebSocketClient@26548549{ST$
2017-03-19 12:50:29.679 [INFO ] [sy.internal.IsyWebSocketSubscription] - Reconnecting via Websocket to Isy.
2017-03-19 12:50:29.714 [DEBUG] [sy.internal.IsyWebSocketSubscription] - Socket Connected: WebSocketSession[websocket=JettyListenerEventDriver[org.openhab.binding.isy.internal.IsyWebSo$
2017-03-19 12:50:29.716 [INFO ] [sy.internal.IsyWebSocketSubscription] - Connecting to :ws://x.x.x.x:xxxx/rest/subscribe
2017-03-19 12:50:29.719 [DEBUG] [sy.internal.IsyWebSocketSubscription] - in finally in IsyWebSocketSubscription
2017-03-19 12:50:29.742 [DEBUG] [sy.internal.IsyWebSocketSubscription] - Control: , Action: , Node:
2017-03-19 12:50:29.776 [DEBUG] [sy.internal.IsyWebSocketSubscription] - Control: _4, Action: 5, Node:
2017-03-19 12:50:29.805 [DEBUG] [sy.internal.IsyWebSocketSubscription] - Control: _4, Action: 6, Node:
